Difference in 93 - 95 LTI motor
Old Jul 2, 2007 | 05:20 PM
Rolnaz's Avatar
Exclamation Difference in 93 - 95 LTI motor
O.K. I am asking again because it was never answered before, which is unusual for this site.
My 93 Z is in need of a head gasket.
I have a 95 non Z LT1 sitting in my shed waiting on a rebuild.
Instead of just doing gaskets why not do a rebuild. I just need to know what all is different in the block, cam and heads, between the 2.
Can I just buy another 93 cam and rebuild everythig else from a 95 motor and call it a day, or do i need to swap more internals?
Old Jul 2, 2007 | 05:27 PM
mobleman's Avatar
Do you mean by non-Z that it was in a b-body? If so it probably has iron heads.. If corvette, aluminum
This is a good website to go to for information on the various years of the LT1:
http://www.f-body.org/tech/ (click on the word "here")
And here:
http://www.automotiverebuilder.com/ar/ar99928.htm
Old Jul 2, 2007 | 07:07 PM
Rolnaz's Avatar
nope it just came out of a 95 camaro non Z28, it had rear drums, auto tranny, plain interrior.
Thanks for the info I will look it up now.
Old Jul 2, 2007 | 07:39 PM
Rolnaz's Avatar
Not the right information for what I am looking for, good info either way, but I need more detailed on the 93 and 95 LT1
Old Jul 2, 2007 | 08:48 PM
nicks2ndZ's Avatar
if it came out of a 95 camaro that wasn't a z28 then its not an LT1 its a 3.4L V6
Old Jul 2, 2007 | 08:53 PM
mobleman's Avatar
And if thats true.. the difference between the 2 motors is... 2 cylinders
Old Jul 2, 2007 | 09:24 PM
Rolnaz's Avatar
a little leason for both of you then ... (not to be rude just making sure this is out there)
93 had a 3.4l V6 and a 5.7 LTI <-- Z28 and a non Z28 with rear drum brakes not disk and no badges still single cat with dual outlet muffler.
95 had 3.4L/207, 3.8L/231 5.7L/350 <-- Z28 and non Z28 with rear drum brakes not disk and no badges still single cat with dual outlet muffler, and I do believe an SS model also.
Thought this was weird too, so I took the vin to the car to my Friend who works at a Gm dealer. Pulled the codes as a Camaro, LT1, no power accesories. No traction control or anything. And yes its a 95 V8 I know what a V6 and a V8 look like, just not familar with the internals of an LT1. standard 350 is a no brainer.
Old Jul 2, 2007 | 09:31 PM
Dave89IROC's Avatar
it will work fine, you will need a 95 opti, or to change the front of the motor over
Old Jul 2, 2007 | 09:45 PM
Rolnaz's Avatar
I have a brand new 93 opti and MSD cap rotor and wires, so I would put a new 93 cam, timing chaing in and swap my timing cover, sound about right ?
Old Jul 2, 2007 | 10:04 PM
The "non Z28" was the B4C "special service package" - essentially a Z28 without the badges. It still had 4 wheel discs. Foglamps were deleted and there were certain restrictions on options. In theory, it could only be bought by and delivered to government agencies.
Old Jul 2, 2007 | 10:27 PM
mdacton's Avatar
you can use the newer cam......its the timing chain you need the one with splines in it. The timing cover has to match the opti its being used with
Old Jul 2, 2007 | 11:31 PM
mrseven's Avatar
The opti, timing chain cover, and cam need to all match for the right year. The 93-94 non-vented opti's were driven by a dowel pin, while the 95-97 opti's were driven by the pin on the cam face. Also, if you decide to swap to a 95 and up setup, you may need a 1LE or equivalent intake elbow to hook up the breather tube for the opti cap. Or just ghetto rig it
Old Jul 2, 2007 | 11:38 PM
fireman's Avatar
I'd like to know more about the mythical non Z28 LT1 Camaro with rear drums.
And there was no SS in '95.
Old Jul 2, 2007 | 11:59 PM
mrseven's Avatar
This "mythical" camaro may have been originally a 3.4L V6, converted to a V8 by the original owner. Check the VIN to be sure. Go here for help on decoding the VIN:
http://www.f-body.org/oldfaq/html/vins/4genvins.html
And the SS option for camaros started in '96. But as far as I know, some lucky people have already gotten their hands on B4C Camaros. I forget which magazine I saw it in, but some guy had one. Rare as they are, I still like seeing the Z28 on my car
Old Jul 3, 2007 | 12:23 AM
pcgamer4life's Avatar
Actually, B4C's aren't all that rare...atleast not around here. There are actually 2 running around in my little ****-ant town in arkansas, not to mention I've seen quite a few listed locally/on ebay in the past few years. Guess all the rednecks got the cool interceptors.
