Did TB bypass- need to "burp" my cooling system???
Old Jul 15, 2003 | 12:24 PM
bad1LEz's Avatar
Did the TB bypass this weekend. When I pulled the hoses off and before I reconnected them, I could here my radiator and ?radiator cap? gurgling. Does this mean I must now bleed the cooling system? Or will it work it's way out. If I need to, where's the bleeding valve? I had good clothes on after and didn't want to lay on the ground, I thought maybe the valve is on the bottom of the radiator. Exactly where?
Thanks alot.
Old Jul 15, 2003 | 12:41 PM
ZDriver96's Avatar
Do a search. Im sure it'll come up if your unsure about something.
there are 2 bleeder valves... they are on the hoses clearly visible and on top of the engine.... having done a tb bypass you couldnt have gotten that much air in there. Just find one of the valves have your car running, and loosen it with a flat head screw driver alittle bit until something comes out. Either air or coolant will come out. if its coolant than shut it again.
Old Jul 15, 2003 | 01:01 PM
Bastardcat's Avatar
Here's a pic (courtesy of shoebox)
http://csce.uark.edu/~jgbertr/rb/bleeders.jpg
Old Jul 15, 2003 | 01:24 PM
bad1LEz's Avatar
Sounds pretty easy. I'll screw it up.
Thanks alot guys.
Magenta_Hearts
Mar 25, 2015 10:24 AM
grgguy
17
Feb 23, 2015 07:57 PM
kksi
Feb 17, 2015 10:41 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
