Did Some 1997 Camaros Come With The Ls1?
Old Jul 14, 2020 | 09:58 PM
  #31
FirebirdGT's Avatar
Re: Did Some 1997 Camaros Come With The Ls1?
Build code sticker in the glove box.
Old Jul 14, 2020 | 10:45 PM
  #32
peterpar's Avatar
There is a book by Robert Casey which states there were 122 Coupes built in 1997 with the RPO LS1. 119 were automatics with a 3:23 rear axle and 3 were six speeds with a 3:42 rear axle. It also states that "the history and intent of these cars are unknown, but they were likely tested and crushed".
The screenshot below shows the index of the book which list a chapter on 96-97 Z28 LS1 and Z28 LB9 Test Cars. This information is supposed to have come from the CompNine website using the RPO data bank. Here's
a link to the book on Amazon a link to the book on Amazon
if anyone is interested.
Old Jul 15, 2020 | 04:01 PM
  #33
VChula's Avatar
Originally Posted by danielaguirre74
Whats a RPO sticker?
Better yet, please message me your VIN number and I will be able to determine your car's configuration.
Old Jul 15, 2020 | 04:30 PM
  #34
danielaguirre74's Avatar
Vin: 2g1fp22g4w2113025
Old Jul 15, 2020 | 04:35 PM
  #35
Old Jul 15, 2020 | 04:51 PM
  #36
VChula's Avatar
According to the search results, your car is listed as a 1998 model and it was built on 10-02-1997 (the "W" in your VIN is a dead giveaway, the 1997 cars have a "V")
Below are all of the VIN attributes:
Model designator: 1FP87 : CAMARO 2 DR
Build Date: 19971002
Year: 1998
Major Division: C :
Car Division: 1 : CHEVROLET
Series code: FP
Bodystyle code: 87
Book: F
Catalog Code: 18F : CHEVROLET
Primary Color Code: 9567 : Arctic White
MOLDING COLOR: 10Q : MOLDING COLOR,ARCTIC WHITE
PRIMARY COLOR: 10U : EXTERIOR COLOR,ARTIC WHITE
PRIMARY COLOR: 10U : EXTERIOR COLOR,PRIMARY
TRIM COMBINATION: 142 : TRIM COMBINATION LEATHER, LT GRAY
TRIM COMBINATION: 14I : INTERIOR TRIM LT GRAY
VEHICLE APPLICATION: 1AZ : SOLD ORDERS
PACKAGE/SALES PACKAGE: 1SG : PACKAGE OPTION 07
FINANCIAL PROGRAM / FLEET PROCESSING: 1SZ
PACKAGE OPTION- COMPONENT FRONT LEFT: 6ZL
COMPONENT FRT LH COMPUTER SEL SUSP (6ZL)
COMPONENT FRONT RH: 7ZL : COMPONENT FRT RH SUSP
COMPONENT REAR LH: 8TH : COMPONENT RR LH COMPUTER SEL SUSP (8TH)
COMPONENT REAR RH: 9TH : COMPONENT RR RH COMPUTER SEL SUSP (9TH)
WINDOW, POWER OPERATED: A31 : WINDOW,ELECTRIC OPERATED,SIDE
WINDOW, POWER OPERATED: A31 : WINDOW,POWER OPERATED,ALL DOORS
LOCK CONTROL, REAR CMPT: A90 : LOCK,REAR COMPARTMENT LID,REMOTE CONTROL,ELECTRIC RELEASE
ADJUSTER FRONT ST: AG1 : ADJUSTER FRT ST POWER, MULTI-DIRECTIONAL, DRIVER
RESTRAINT SYSTEM: AK5 : RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE,DRIVER AND PASSENGER
SEAT: AR9 : SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE)
LOCK CONTROL, ENTRY: AU0 : LOCK CONTROL,REMOTE ENTRY(KEYLESS ENTRY SYSTEM)
LOCK CONTROL, DOOR: AU3 : LOCK,SIDE DOOR,ELECTRIC
FLOOR COVERING: B35 : COVERING,FLOOR MATS,REAR,CARPETED INSERT(COLOR COORDINATED)
MOLDING - B/S: B84 : ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING
DEFOGGER: C49 : DEFOGGER,REAR WINDOW,ELECTRIC
HVAC SYSTEM / INTERIOR HEATER: C60 : AIR CONDITIONER,FRONT,MANUAL CONTROLS
ROOF: CC1 : ROOF,HATCH,REMOVABLE PANELS,GLASS
MIRROR O/S: DE4 : SUNSHADE,REMOVABLE HATCH ROOF
MIRROR O/S: DG7 : MIRROR,OUTSIDE,RH & LH REMOTE CONTROL,ELECTRIC(PAINTED)
DECAL: DL5 : DECAL ROADSIDE SERVICE INFORMATION
SUSPENSION SYSTEM: FE2 : SUSPENSION SYSTEM,RIDE AND HANDLING
CERTIFICATION: FE9 : FEDERAL EMISSION CERTIFICATION
AXLE POSITRACTION: G80 : AXLE,REAR,POSITRACTION,LIMITED SLIP
AXLE REAR: GU5 : AXLE,REAR,3.23 RATIO
INTERIOR TRIM PANEL: IP2 : TRIM,INTERIOR DESIGN
BRAKE SYSTEM: J65 : BRAKE SYSTEM,POWER,FRONT AND REAR DISC
CRUISE CONTROL: K34 : CRUISE CONTROL,AUTOMATIC,ELECTRONIC
GENERATOR: K68 : GENERATOR,105 AMPERE
ENGINE: LS1 : ENGINE GAS, 8 CYL, 5.7L, SFI, ALUMINUM ENGINE
TRANSMISSION: M30 : TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC
MERCHANDISED TRANS: MX0 : TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION)
WHEEL: N96 : WHEEL,16X8(CAST ALUMINUM)
EMISSION SYSTEM: NF2 : EMISSION SYSTEM,FEDERAL,TIER 1
STEERING WHEEL: NP5 : STEERING WHEEL,LEATHER WRAPPED
TRACTION CONTROL: NW9 : TRACTION CONTROL ELECTRONIC
TIRE ALL: QFZ : TIRE ALL P245/50ZR16 BW R/PE ST TL AL3
FINANCIAL PROGRAM / FLEET PROCESSING: R7A : CONTROL SALES ITEM NO. 26
FINANCIAL PROGRAM / FLEET PROCESSING: R8T : CONTROL-SALES ITEM NO. 69
FINANCIAL PROGRAM / FLEET PROCESSING: R9U : CONTROL - SALES ITEM NO. 95
FINANCIAL PROGRAM / FLEET PROCESSING: R9Z : CONTROL - SALES ITEM NO. 100
PLANT CODE: STE : PLANT CODE- ST THERESE, PQ, GM OF CANADA
HEADLAMP CONTROL: T82 : HEADLAMPS,AUTOMATIC ON/OFF CONTROL
FOG LAMP: T96 : LAMP,FRONT FOG
ANTENNA: U73 : ANTENNA,FIXED
THEFT DETERENT SYSTEM: UA6 : THEFT DETERRENT SYSTEM
CLUSTER: UB3 : CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER)
RADIO: UL0 : RADIO AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC SEARCH CASS, AUTO TONE, CLOCK, ETR.
: UZ7 : SPEAKER SYSTEM 8, QUAD FRT DR MTD, DUAL SAIL PNL, DUAL RR HATCH, AMPLIFIER
VEHICLE STATEMENT: V73 : VEHICLE STATEMENT - US/CANADA
LICENSE PLATE, FRONT OR REAR: VK3 : LICENSE PLATE,FRONT MOUNTING PACKAGE
LABEL: VM3 : LABEL INFORMATION CONSUMER, CONTAINS BPR IMP STANDARD FOR FRT 5 MPH & RR 5 MPH
MERCHANDISED PACKAGE: Z28 : SPECIAL PERFORMANCE PACKAGE,(MERCHANDISING OPTION)
Submodel: 450 : Z28
Wheel Base (Inches): -
Wheel Base (Metric): -
Region: 1 : USA United States
Engine Designation: 115 : LS1
Engine VIN: 29 : G
Valves: 3 : 16
CC: ECC#- : -
CID: ECD#350 : 350
Liter: ENL#5.7 : 5.7
Engine Bore (Inches): EBR#3.90 : 3.90
Engine Bore (Metric): EBM#99.0 : 99.0
Engine Stroke (Inches): EST#3.62 : 3.62
Engine Stroke (Metric): ESM#92.0 : 92.0
Cylinders: CYL#8 : 8
Fuel Delivery Sub Type: 5 : MFI
Fuel Delivery Type: 5 : FI
Fuel System Control Type: 5
Fuel System Design: 6 : SFI
Aspiration: 5 : Naturally Aspirated
Cylinder Head Type: 7 : OHV
Fuel Type: 5 : GAS
Ignition System Type: 6 : Distributorless
Engine Manufacturer: 11 : General Motors
Engine Version: 5 : Chevrolet
Power Output (Horse Power): U/K
Power Output (Kilowatt Power): U/K
Body Number of Doors: 7 : 2
Body Type: 9 : Coupe
Bed Length (Inches): N/R
Bed Length (Metric): N/R
Bed Type: 3 : N/R
Brake Type (Front): 5 : Disc
Brake Type (Rear): 5 : Disc
Brake System: 5 : Power
Brake ABS: 8 : 4-Wheel ABS
Spring Type (Front): 5 : Coil
Spring Type (Rear): 5 : Coil
Steering Type: 6 : Rack
Steering System: 5 : Power
Transmission Type: 5 : Transmission
Publication Stage: 4
Engine Block Type: BLT#V : V
Old Jul 15, 2020 | 05:07 PM
  #37
So..............then its not a 1997 year model?
Old Jul 15, 2020 | 05:10 PM
  #38
Hey guys, I'm new to the forum. I know this is an old thread, and there a lot of opinions about the 1997 Camaro with the Ls1. I recently acquired a 1997 Camaro and it has the Ls1 in it, and its a T-top car. Pretty clean car all things considered. The only reason I got the car, was to pull the engine, tranny, and rearend, to use in another project. My question is.........Would this car be considered Rare to any degree? I'd sure hate to tear this car apart, and then years later regret destroying one of God's great creations. I could easily use a 5.3 in its place or even find another Ls1 from a wrecked vehicle...... What are your thoughts, or opinions. Thanks in advance.
Somebody actually told you this was a 1997, and you believed them?
Old Jul 15, 2020 | 05:21 PM
  #39
Why would I care either way. I just bought the car as a doner, for a really good price. I really didnt care what year it was. But when we were looking for the year model, the door sticker said 1997.........My buddy said that it was impossible, and the LS1 didnt come out in a Camaro till 1998. So............ while doing some research, I happened upon this thread, and here we are. And if it was something special, I did not want to tear it apart, and regret it later.
Old Jul 15, 2020 | 05:25 PM
  #40
So technically it was built in 1997, but for the 1998 year model. Right? And so its no big deal to strip this car, and scrap the rest...........?
Old Jul 15, 2020 | 06:40 PM
  #41
But surely you are aware that the new car “model year“ usually starts building many months earlier in the previous year. Common for almost all production vehicles.
The build date has NOTHING to do with the model year. Your car is NOT a 1997 with an LS1 engine. There are 2021 model year vehicles already being built, and in some cases sold.
Old Jul 15, 2020 | 06:46 PM
  #42
VChula's Avatar
Yes sir.
The 1998 model year production probably began somewhere around August of 1997 (plus or minus a month).
Old Jul 15, 2020 | 08:01 PM
  #43
All documentation appears to say it is a 1998. So, does the exterior look like a 93-97 or 98-02?
Old Jul 15, 2020 | 08:47 PM
  #44
I'm not sure. The frontend s different than the 95 I have.The 98 has bubble looking headlights. I don't know too much theses Camaro's. Anything I know about theses cars, I"ve learned from reading old threads from you guys. Thanks for all the help, and input. Even the sarcastic input. If anything, I'll have alot spare parts if anyone is interested. I'll be using most of the mechanical parts. But all of the body parts will be up for grabs. Thanks again guys.
Old Jul 16, 2020 | 12:00 AM
  #45
98 Camaro had a new front end, compared to 93-97. Often described as a “fish mouth” grill.
https://www.edmunds.com/chevrolet/camaro/1998/pictures/
