Did LCAs help your traction that much?
Old Nov 2, 2003 | 01:49 PM
94 CAMRO Z28's Avatar
I just can't seem to get off the line well at all. Even with Nitto DRs I still seem to either bog it down or light up the tires. I dont want to ride the clutch a lot either. So much question is how much did LCAs help your traction? What about a TA or subframes? Thanks
Aaron
Old Nov 2, 2003 | 01:52 PM
Prorac1's Avatar
i sympathise with ya, i got an auto so its easy. The only way with a 6 speed to get good 60ft times is either do it or dont do it at all approach. Et streets, strong rearend, good clutch, and high rpm clutch drops. just my .02 . Prorac1
Old Nov 2, 2003 | 01:57 PM
Got-LT1's Avatar
I had a big problem with tire spin so I tried an airbag in the rear coil springs, works real good and only cost ~$40.
Old Nov 2, 2003 | 02:56 PM
Javier97Z28's Avatar
Moderator
They killed my wheelhop back when I was stock ages ago, so they work very well
Old Nov 2, 2003 | 03:20 PM
MadMaxz28's Avatar
an airbag in the P/S spring is the key. LCA will help alot too. and dont forget weldin relocation brackets but make sure they are installed RIGHT!
Old Nov 2, 2003 | 03:23 PM
Seal's Avatar
airbags would def help imo... u can set it so even at 600rwhp u can launch it right, cuz its FULLY adjustable
my friend has them, and instead of only 1 on the right side, he has 1 on the left side too but i dunno why :P i guess he makes that side alot firmer or something
Old Nov 2, 2003 | 03:29 PM
Anyone have a part number for this airbag? Where can I buy one also? Summit?
Aaron
Old Nov 2, 2003 | 03:34 PM
Got-LT1's Avatar
http://www.ls1speed.com/catagory.cfm...ory=suspension
look a little more than halfway down on that page. It's called the Airlift Airbag Set.
Geezer powered's Avatar
Well I don't know if your car is lowered but relocating brackets will help. If it is you will enjoy the new found ride quailty you missed fromlowering it
Old Nov 2, 2003 | 04:03 PM
Car is not lowered but thanks.
Aaron
96SilverRam
Nov 20, 2016 11:19 AM
Henson071
Dec 30, 2015 09:55 PM
Henson071
Sep 18, 2015 04:01 PM
Boss002
Jul 24, 2015 10:47 AM
