diagnostic trouble code scanning.
Old Jul 12, 2004 | 09:02 AM
lovescamaros25's Avatar
i just want to know is there an alternative to going to a shop and having a computer on a camaro scanned to find a trouble code,dont think make some time of cable you can buy or something to do it yourself?
Old Jul 12, 2004 | 09:44 AM
You can buy a hardware "scanner" like the Auto Xray (~$170), a ScanMaster ($250) or one of the Actron units.... but do NOT buy the $30 Actron "code reader" because that only works on the 93, with "short-the-pins" capability. Will NOT work on 94 and up.
Alternatives are software data logging systems - TTS DataMaster (free download, 20 free uses); FreeScan (free download), Diacom (outdated POS) and pcmcomm (bundled with LT1_Edit programming software). Then you need a cable from AKM Electronics to connect your laptop to the ALDL connector under the dash (~$50-100).
All of these systems go beyond simple "code reading", allowing you to look at the critical engine sensors, PCM parameters, etc.
armedtrigger
Feb 24, 2015 08:30 PM
David Dorris
Jan 17, 2015 08:10 PM
Jul 4, 2005 05:00 PM
91Bird305
Aug 5, 2002 01:39 PM
LT1
Jul 2, 2002 08:27 PM
