Dexcool to Regular Anti-Freeze conversion.
Old Nov 10, 2003 | 10:03 AM
S.J.S.'s Avatar
I heard of guys doing it. I was wondering if its okay for the motor or should I just stay with the Dexcool?
Old Nov 10, 2003 | 11:44 AM
moparman's Avatar
Stay with the Dexcool. That's what your car is designed for.
Old Nov 10, 2003 | 12:57 PM
ead94z28's Avatar
Last month I wanted to do a coolant flush, so I called the dealer to find out what to put in the system. Surprisingly he told me to put the green stuff in. He said it doesn't last as long as dexcool, but it is better for the system. Right or wrong? I dunno. I honestly don't believe there is a difference, other than longevity, but thats just me. The only thing is, the system has to be completely flushed if you are going from one to the other, because the green will destroy the efficiency of the dexcool.
Old Nov 10, 2003 | 03:31 PM
Josh-'04 GTO's Avatar
That would be a big fat wrong. Green stuff has a much higher concentrate of silica, which kills off water pumps. The Dexcool also does a better job of transferring heat. Don't waste your time with the green stuff.
Old Nov 10, 2003 | 04:37 PM
ead94z28's Avatar
Good to know that my dealer is a friggin idiot!!
Old Nov 10, 2003 | 08:34 PM
Most are! Don't feel bad, it took mine FOUR tries to change a windshield washer fluid reservoir!!! If the car hadn't been under warranty at the time I would have never let them put their greasy paws on it.
Old Nov 10, 2003 | 08:46 PM
Z28Boss's Avatar
I have a 95 Z28 and I have been using the green stuff. Was my car made to use the green stuff or am I putting the wrong antifreeze in my car??
Old Nov 10, 2003 | 08:50 PM
Your car came stock with Dexcool. There will always be people who are resistant to change and ignorant to new technologies...and one of them put green coolant in your car! It's not the end of the world, but the next time you do a flush I'd put the Dexcool back in.
Old Nov 10, 2003 | 08:53 PM
Z28Boss's Avatar
Sounds good to me. I bought it a year ago and have always used the green crap since thats what was in it when I bought it. I will have to change that.
Old Nov 10, 2003 | 09:06 PM
gb95zconv's Avatar
Not in 95....They came with green stuff. After 95 they came with dexcool.
Old Nov 10, 2003 | 09:44 PM
Z28Boss's Avatar
Ok well now I have two people telling me different things. Anyone know for sure who is right?? I would tend to listen to the guy WITH the 95 Z.
Old Nov 10, 2003 | 10:29 PM
CamaroBoy96Z28's Avatar
I'm fairly sure that pre-95s came with the green. My car came with Dexcool and thats what I use. Even if your car came with the green stuff I'd still switch to Dexcool. Better heat transfer and being better on the waterpump seals helps.
Old Nov 10, 2003 | 10:53 PM
Z28Boss's Avatar
sweet, sounds good, thanks for the help!!
Old Nov 10, 2003 | 11:04 PM
Laymaster's Avatar
when I got my car used, it had the green stuff in it. However, the manual calls for dexcool, so I would assume it came with dexcool from the factory.
Formula Steve
Sep 19, 2023 08:31 AM
Henson071
Sep 18, 2015 04:01 PM
cmsmith
Sep 14, 2015 09:25 PM
Pwilson59
Sep 3, 2015 08:47 PM
asilomar244
Jul 12, 2015 05:53 AM
