Dent in the oil pan?
Old Jul 7, 2004 | 10:48 PM
94TA25ann's Avatar
Angry Dent in the oil pan?
When I was installing my new motormounts I used a block of wood on my floor jack to jack up the motor under the oilpan. Well everyhting went fine on the drivers side but when I was doing the passenger side I noticed I had dented the oilpan a little. It looks like I the edge od the wood put a dent across the oiplan. the dent is probably 1/4'' deep. My question is do you guys think this will cause any problems? Thanks
Old Jul 7, 2004 | 10:51 PM
25thBird's Avatar
I dented mine a bit, while putting in the passenger side header. No problems so far and have been running like that for over a month now.
Old Jul 8, 2004 | 12:42 AM
crAzy95z28's Avatar
same here....i dented maybe 1/4 of an inch up...still no problems and its been about 3-4 months..
Old Jul 8, 2004 | 12:52 AM
94TA25ann's Avatar
I was hoping it wasn't going to be a problem, because I didn't feel like putting a differnt oil pan in(that will cme when the engine gets built some day). I don't think it should be a problem.
Old Jul 8, 2004 | 04:31 AM
HungryT/A's Avatar
I have dented the oil pan while jacking up the motor with two big 'city telephone books'. I was worried first, but then looked into the oil drain hole and saw the pickup was still on. If you can't see the pickup, knock the pan with a rubber mallett and you if you weren't lucky enough, you should hear the pickup rattling at the bottom of the pan.
I guess the LT1 is just too damn heavy for jacking it up at the oil pan...:blah:
HectorM52
Jul 30, 2017 11:46 AM
willismoons
May 27, 2015 04:03 PM
SergheiS
Apr 26, 2015 08:15 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
