Delteq question
Old May 6, 2004 | 06:18 PM
WhoomWhaatWhaah's Avatar
Delteq question
I got the coils and brackets from a 4.8 gmc, anything else I should have gotten.
Old May 6, 2004 | 07:43 PM
kmook's Avatar
Advanced Tech Moderator
Ignition Module comes to mind. Are you sure those coils will work with the system? I haven't heard of those being used.
Why don't you check with Delteq on what exactly you need?
Old May 6, 2004 | 07:52 PM
they were free
Old May 6, 2004 | 09:36 PM
4drLT4's Avatar
Originally posted by WhoomWhaatWhaah
they were free
Well...if they don't work with the Delteq, then they'll be worth exactly what you paid for them.
Congrats on yer freebie, but you'd better make sure those will work.
Old May 6, 2004 | 10:09 PM
Re: Delteq question
Do you mean the 8 individual LS1 style coils used on the 4.8L Chevy/GMC 1/2 ton pickups from 1999-present? If so, you have the wrong coils. The Delteq uses the "wasted spark" principle, and requires 4 dual-tower coils that fire two cylinder simultaneously. Same type they use in the F-Body V6's, the Buick GN/GNX engines.... but more specifically, the dual-tower coils from a Northstar or the Oldsmobile version. I though you needed the Northstar ignition driver module as well.... but I could be wrong.
Old May 6, 2004 | 10:48 PM
Dave88LX's Avatar
If it doesn't look like this then you have the wrong parts...free or not.
http://paradox.shacknet.nu/dave88lx/...coilpacks3.jpg
That metal "plate" on the bottom is the ignition module, and you need that too.
You need the coilpacks off the Caddy Northstar, or the Oldsmobile Aurora V-8's.
Search Ebay for good deals, got mine for $120 w/ module.
Old May 6, 2004 | 10:53 PM
SS MPSTR's Avatar
<off topic>
Dave, clear out your PM mailbox.
Old May 6, 2004 | 11:31 PM
Alex94TAGT's Avatar
Dave -- is that mounting plate fixed to the ICM?
FYI -- If you order the assembly thru Delteq, it does not come with the same type of metal mounting plate on the bottom of the ICM. At least, it's not one-piece.
The valvecover mounted kit (Caprice/Impala) comes with a bracket and heat sheild custom-made by Delteq. I would assume the same applies for the radiator-shroud mount, judging by the photos.
So, if your 'junkard/take-off' coils dont come with a bracket, it's nothing to worry about. You can most likely order the brackets thru Delteq for a reasonable price.
Also, dont let the photos fool you -- the coil assembly is rather large -- it weighs a solid 5 pounds, and the coils are about the size of my fists:
http://hometown.aol.com/alex94tagt/images/coils1.jpg
http://hometown.aol.com/alex94tagt/images/coils2.jpg
The coil packs are used on about a jillion GM cars, but you must have the coil module from a V8 like the Northstar.
Old May 6, 2004 | 11:42 PM
Dave88LX's Avatar
Sorry I'll clear out my box.
Try this on for 'size'
http://paradox.shacknet.nu/dave88lx/...coilpacks1.jpg
Old May 7, 2004 | 02:37 AM
madhatter's Avatar
MSD also makes some aftermartket coil packs.
Old May 7, 2004 | 10:30 AM
damn I though I had came up, What about this LTCC systems that uses the ls1 coil packs. I think the truck was a 01 yukon and from what i read in GM Hi tech, all LS1 parts are interchangable, call me out if i'm wrong
Old May 10, 2004 | 09:11 AM
HOZZ4's Avatar
WhoomWhaatWhaah
The coils you have will not work with our system...we need to use the Cadillac Northstar/Olds Aurora coilpack from 1994-1999.
Give us a call with any questions!
Pete Visser
Delteq
703-476-3566
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
Ari G
Dec 11, 2014 03:21 PM
