Delteq ignition setup, Round 1
Old Mar 18, 2006 | 07:41 AM
  #16
95 TA The Beast's Avatar
Re: Delteq ignition setup, Round 1
You ask, and you shall receive: Delteq Stuff
I know, I should go through and weed out the not-so good ones, as well as revise it a bit, but I am still 'working on other things' at that moment, so it'll have to wait...
Old Mar 21, 2006 | 01:48 PM
  #17
2QUIK6's Avatar
Originally Posted by 97SLPcamaroSS
ok was looking at the site and said someithing like all your current opti proublems have to be solved. So since my opti is bad and wanted to run this kit i still would have to buy a new opti to make this kit run
From what I understand, only the optical sensors need to be working in your existing opti. So if your existing opti is failing due to the cap or rotor, which is the most likely failure point, you would not need to buy a new opti.
I'm not sure if there is a way to test it to find out if the optical sensors are ok or not...anyone know??
Old Mar 21, 2006 | 02:25 PM
  #18
"White Knight"'s Avatar
Your mouting plate is so shinny Mine had the center hole in the wrong place. I had to drill it out myself. They said they had it fixed but I must have got a bad one. Said I could get a new one, but never bothered but if they look that nice than man maybe I will.
Old Mar 21, 2006 | 04:07 PM
  #19
96SilverRam's Avatar
Actually the mounting plate is not that shiny I bought the billet plate and had it polished then chromed
Old Apr 23, 2006 | 06:39 PM
  #20
I thought I would bring this to the top so people could see ROUND 1 and then look at ROUND 2 .
DirtyDaveW
Dec 1, 2016 05:37 PM
Gio93z
May 21, 2015 02:56 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Ari G
Dec 11, 2014 03:21 PM
