delteq and arcing wires
Old Nov 8, 2005 | 12:42 PM
  #31
firebirdStud's Avatar
Re: delteq and arcing wires
well, just gapped to .035, no luck. It didn't fiz a damn thing. Still irratic idle, but seems to almost disapear under load. what gives??
Old Nov 8, 2005 | 03:04 PM
  #32
ManicHaze's Avatar
lowering the voltage going into the coils would lower the output voltage. if the output voltage is lowered some, it shouldnt arc...not sure what the best way to go about lowering the input voltage is though. just a thought.
Old Nov 8, 2005 | 06:09 PM
  #33
1badasZ's Avatar
so the map sensor code is no issue?
Old Nov 8, 2005 | 10:15 PM
  #34
map sensor code? I don't have any codes showing up. I just cleaned the grounds too, and I tried the stock wires. They arced too. What the hell else can it be?
Old Nov 8, 2005 | 11:50 PM
  #35
I can easilly understand your confusion at this point, since "firebirdStud" has highjacked YOUR thread, and turned it into HIS thread. You might want to start all over again.
Old Nov 9, 2005 | 07:03 PM
  #36
1badasZ's Avatar
i'm the one with the map sensor code. and what can you do to detect a vaccum leak?
Old Nov 16, 2005 | 11:10 PM
  #37
1badasZ's Avatar
well i guess i found my problem...something inside my opti is loose as hell...even tho i have a delteq it still reads off the opti doesnt it? whatever it is is rattling bad. and on top of that i have a rocker loose and it would be on the drivers side lol so now i gotta take all that stuff off and still have to buy an opti i cant win
Old Nov 19, 2005 | 05:57 AM
  #38
Guest47904's Avatar
Guest
Your opti may be rattling but there is nothing that could go wrong with it that would create an "arcing" problem. Particularly since your high voltage is coming from the Delteq.
If your thinking your low voltage reference signals from the opti where the problem, you would be setting codes. Are any codes present?
If you're using the 'wasted spark" type of coils, I think, not sure but the base the coils plug into can and will go bad often. It seems that because your having backfire issues, your spark timing is off. I would look into the coil packs your using. I'm no expert on DIS so a question or 2 to a mech that works with them all the time can go a long way.
I did ask the question about the coil packs to a friend with a shop and if they are the style that they use on the 4.3's. The module that the coils plug into is definately a problem often.
Critter
Jul 7, 2015 08:33 PM
Ari G
Dec 11, 2014 03:21 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Brian Demeter
Aug 17, 2002 08:07 PM
