delteq
Old Nov 14, 2012 | 11:58 AM
summer nights's Avatar
delteq
Anyone that has run this system,is it worth it?
Old Nov 14, 2012 | 12:06 PM
Ultra_Dog's Avatar
Re: delteq
I put a Delteq on my 96 after my 2nd opti went out. It worked just great until the "brain" overheated (too close to hot engine area). I replaced that and had zero problems since.
PS: I put a heatsink on the new brain and made sure it wasn't bolted to anything that conducted heat. Insulating it helps too.
Other than that...I never had to fiddle with the stupid optispark again.
That was worth the cost in itself.
Old Nov 14, 2012 | 12:31 PM
slick1hunting's Avatar
Re: delteq
They are no longer in business so no tech support or replacements. Quite a few people have had the "heat" issue. If I were you looking for the coil conversion id go check out the ltcc. Its still in production and has tech support and even still tests the brain.
Old Nov 19, 2012 | 03:04 PM
will.b.brown's Avatar
Re: delteq
I've had the delteq system for about 8 yrs now with no problems. But yeah they dont exist anymore so you should definitely go with the ltcc. I'm just waiting on the day mine fails and I'll be going with the ls-1 style ignition. I've completely relocated the brain from the front of the cylinder head over to the wheel well. Away from all heat
Old Nov 19, 2012 | 03:06 PM
Re: delteq
It HAS been pretty great not dealing with the opti-crap tho.
tommalcolm
Sep 11, 2015 03:39 PM
POLOVETTE 94
Aug 21, 2015 07:11 PM
Ari G
Dec 11, 2014 03:21 PM
Maldo
259
Feb 22, 2005 10:14 PM
