Delteg System
Old Sep 2, 2004 | 10:15 AM
"White Knight"'s Avatar
Delteg System
I was wondering how many of you have the valve cover mount and how many have the lower radiator mount type. I have to order mine soon and need to decide. I would like it up on the valve cover but wouldn't the heat get to it? So i just wondered what you guys had and which you liked. I sure hope this will take away my total drop off at 4,700rpm----the motor just stops basically......lol
Old Sep 2, 2004 | 04:04 PM
aintno6's Avatar
Re: Delteg System
Its called Delteq FYI
I just installed one in my car last night. I went with the radiator mount. And man that install was pretty easy. I really like the way its setup.
Personally I think the valve cover mount looks pretty cool. From what the instructions say, it comes with a heat shield. And on many coil pack cars tend to have theirs mounted on the valve covers, or near them, from the factory. So I dont think heat is a problem.
The reason I ended up going with the radiator mount, is because I felt routing the wires from the bottem was much simpliar, and also because I planned on running aftermarket valve covers. So I didnt want the delteq to cover up the bling bling lol.
Mike
Old Sep 2, 2004 | 05:02 PM
1Qwik94Z's Avatar
Re: Delteg System
you guys got a link to the ones you have or are going to get? Any pics of either method, valve cover setup or radiator setup? (i mean real pics..not the fabbed up slick ones on the product sites)
Old Sep 2, 2004 | 06:02 PM
kmook's Avatar
Advanced Tech Moderator
Re: Delteg System
I dont think heat is an issue on the valve cover mount. I had mine mounted to the intake manifold for many months now and have no issues with heat-
http://community.webshots.com/photo/...29833547CyrIPu
Old Sep 3, 2004 | 07:39 AM
Zepp's Avatar
Re: Delteg System
I installed mine on the radiator / fan shroud. I think it looks a lot neater than on the valve cover.
Old Sep 3, 2004 | 10:28 AM
ronin013's Avatar
Re: Delteg System
wow that looks pretty good on the intake manifold.
i put mine down by the radiator to keep it out of the way. keep the engine bay a little neater and simpler when i open the hood for people.
install was easy as pie though. good stuff
Old Sep 3, 2004 | 11:46 AM
aintno6's Avatar
Re: Delteg System
for you guy who went with the radiator mounted unit. Are you running heat shields for the wires?
Mine looks like it wont need them. But I wonder if I should just get them just in case.
Mike
Old Sep 3, 2004 | 11:57 AM
Fastbird93's Avatar
Re: Delteg System
That's actually pretty cool looking!!!!
malikot02SS
Aug 15, 2015 01:11 PM
350350
14
Aug 11, 2015 12:03 PM
MikeWhitener
Aug 2, 2015 06:17 PM
RUNMYTA
Jul 15, 2015 07:50 PM
