Deleting EGR, AIR, etc - Questions on Intake Manifold
Hey guys,
Disclaimer: I have had a 3.4L v6 since 2002. In October I bought an LT1 and started building it up. So I'm a virgin to the LT1s.
So when I bought EGR blockoff plates, it was for the back of the intake manifold and one for the exhaust manifold. What do I do with the vacuum lines that are on the intake manifold that are for EGR and AIR? Do I just thread a solid bolt in or leave the nipple open [thus introducing a vacuum leak?]?
Also, and I apologize for how newb these questions are - I bought the AIR blockoff bolts. Where do those go and are there any other secondary lines that must be closed up?
I ditched mine when I did headders. I did the block off plates like you mentioned. Plug the manifolds however you can, not sure if they make high temp thread sealant. Remove the air pump when you do it, that will get rid of that pump.
about the vaccume lines plug them with brass plugs. and on the headers for the air pump delete i used 2 1/2 inch pipe plugs and put them in as tight as i could. First time i did the plugs on the headers with nitrous i blew them out. havnt hit the button since.
Never leave a vacuum nipple open.
These are the parts you would be removing (courtesy of Shoebox):
http://shbox.com/1/diverters.jpg
You can see where the tubing flare nut threads into the exhaust manifold on each side.
Your air intake ducting, from the filter to the MAF sensor will have a 5/8" connection on it for the air supply hose to the AIR pump. That connection also has to be capped with a 5/8" vacuum cap, or you will be pulling unfiltered air into the engine.
Again, depending on the year of the PCM, you may have to have the codes/SES light turned off when you remove the AIR and EGR. 96/97 OBD-II PCM's are the most critical in that respect.
Thanks for all the information! So it looks like I bought the AIR block offs when I didn't need to - bought LPP s.s. headers with ORY and I don't believe they have the openings for AIR. Also, thanks for the information on the nipple plug (sounds dirty LOL). I'll definitely have to look into that.
ModdedNerd
Dec 14, 2014 10:28 AM
Jul 4, 2005 05:00 PM
turbo_Z
Aug 19, 2002 10:50 PM
