Delete Opti or no????
Old Nov 18, 2010 | 01:24 PM
  #16
bw_hunter's Avatar
Re: Delete Opti or no????
Originally Posted by FastandBlue
I'm sold. But yeah, that's why I said "negligible Hp gain" in my beginning post. This helps a lot though. Two quick questions:
1. How much longer will it honestly take to install for someone who hasn't ever done this before?
2. Is the 95 TA LT1 and 95 Z28 LT1 the same?
Thanks!
If you've never do it before but know what needs to be done, I would think you could change the timing set out in a few hours...figure on a Saturday. The only thing you have to pay a lot of attention to is lining up the timing marks. Ge that wrong and you'll have a seriously weak engine....might not even run at all.
Yet, the LT1 power in Pontaics and Chevys is the same....
Old Nov 18, 2010 | 01:30 PM
  #17
RamAir95TA's Avatar
Thanks!
1.) Like mentioned, probably a day or two if you've never done it before. You'll spend alot of time familiarizing yourself with everything.
2.) Yep.
Old Nov 18, 2010 | 01:31 PM
  #18
FastandBlue's Avatar
Okay great, thanks! I'll do those two mods then while I am down there. Any good recommended tuts on the timing set?
Old Nov 18, 2010 | 01:39 PM
  #19
RamAir95TA's Avatar
Not sure what a tut is, but Cloyes 3145 is what I use (and it seems alot of other people use too).
Old Nov 18, 2010 | 01:46 PM
  #20
bw_hunter's Avatar
I have a guess..a tutorial?
If that's what he's after, he should go buy a haynes manual
Old Nov 18, 2010 | 01:48 PM
  #21
lol, sorry, programmer language from my IS days. I was just hoping for a "tutorial" with pictures maybe?
Old Nov 18, 2010 | 04:25 PM
  #22
The LT4 Extreme Duty cam sprocket is godawful heavy..... they built it with a solid web reportedly to help tame the LT4's cam torsion. But it doesn't have to stay that way.
http://www.injuneer.com/images/photo.../newfront.jpeg
I'd still wait with replacing the timing set until you rework the rotating assembly.
Old Nov 18, 2010 | 08:23 PM
  #23
Aww dang. This is getting expensive fast. I don't plan on working on the rotating assembly any time soon. What advantage is there to waiting, in all honesty? I mean, if I rework the rotating assembly, we're talking as much work as a rebuild here for me in terms of access. Is there a disadvantage to replacing the timing set before I do this. As hunter said, I'll probably go with the Cloyes and a EWP along with a new opti. But yeah, why rework the rotating assembly. Sounds like a PITA for where I am at right now.
Old Nov 18, 2010 | 10:29 PM
  #24
I'm not suggesting you arbitrarily rework the rotating assembly so you can use an upgraded timing set. I'm suggesting that LATER, when you go for the 500HP build, you will THEN need to upgrade the rotating assembly, and that's when it would make more sense to upgrade the timing set.
That's why my engine has the LT4 ED set, with the cam sprocket web machined to reduce weight. I was building a stroker, and everything else in the rotating assembly was brand new, and upgraded.
Old Nov 19, 2010 | 12:20 AM
  #25
MikeGyver's Avatar
In my experience changing the timing set takes considerably longer than just changing the opti.
Old Nov 19, 2010 | 01:06 AM
  #26
Injuneer:
Gotcha. Yeah I may just wait then, but we'll see. I'm in a tough spot because I eventually want a 383 in here, so I don't want to do too much work. At the same time I wouldn't mind getting more power until I do that and I want to make sure that the current chain will hold up alright. We'll see, anyway.
Old Nov 19, 2010 | 06:49 PM
  #27
Javier97Z28's Avatar
Moderator
Wait on the timing set till you do a cam or something along those lines.. that's the time to be messing with that kind of stuff.
Old Nov 20, 2010 | 08:24 PM
  #28
Will do... Thanks for the input.
Old Nov 23, 2010 | 02:01 AM
  #29
96LT1TX's Avatar
You have to take it off any way to do the cam install; that is when I installed mine. Also, if you are thinking about buying it in the near future I believe some people have clearance issues with the double roller... it has been years since I did the install but for some reason I remember clearancing something? Just another added step...
It seems we got way off topic, why did you originally want to delete the opti? Was it for ease of maintenance (less opti replacements)? Or was it for HP gains? If it was for HP gains, I don't think you will see much.
Formula Steve
Sep 19, 2023 08:31 AM
Nayr
Mar 3, 2023 08:34 PM
tdigger9899
Sep 7, 2015 10:56 AM
tnmotown
Aug 10, 2015 11:52 PM
asilomar244
Jul 12, 2015 05:53 AM
