degreeing a cam??
Re: degreeing a cam??
I dont want to confuse this so the easiest way to explain is dot-to-dot. The dot on the cam(large) gear should be at 6 o'clock and the dot on the crank(small) gear should be at 12 o'clock.
Originally Posted by chevy1963
What is the built in advance on a 306 cam? when I stalled mine I just put the dowel pin at 3 o'clock. Is that bad? could I be losing power?
