degreeing a cam??
Old Jun 2, 2005 | 11:41 AM
chevy1963's Avatar
degreeing a cam??
What is the built in advance on a 306 cam? when I stalled mine I just put the dowel pin at 3 o'clock. Is that bad? could I be losing power?
Old Jun 2, 2005 | 11:50 AM
turbo_Z's Avatar
Re: degreeing a cam??
4 degrees ground into the cam and you should install it straight up. #1, #6 at TDC and cam at 3 o'clock like you said is right.
Old Jun 2, 2005 | 11:58 AM
chevy1963's Avatar
Ok, the timing when I put it on, little gear @ 12 and the big gear @ 6 and the cam @ 3 Correct?
Old Jun 2, 2005 | 12:08 PM
turbo_Z's Avatar
I dont want to confuse this so the easiest way to explain is dot-to-dot. The dot on the cam(large) gear should be at 6 o'clock and the dot on the crank(small) gear should be at 12 o'clock.
Old Jun 2, 2005 | 12:10 PM
chevy1963's Avatar
Yea thats what I was saying, sorry if i confused you.
Old Jun 3, 2005 | 06:26 PM
arnie's Avatar
So what does this thread have to do with the title, 'degreeing a cam'?
Old Jun 6, 2005 | 07:07 AM
chevy1963's Avatar
uummmm degreeing a cam before installing??????
Old Jun 6, 2005 | 08:03 AM
rskrause's Avatar
Moderator
Hey Arnie: I knew you would be all over that one!
Rich
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
thenewkid
Apr 12, 2015 07:42 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
