Daytime running lamps for 95TA
Old Jun 26, 2003 | 09:41 PM
  #31
jwar19's Avatar
Ok, inside of the bulb, there are TWO wires, or filaments, whatever their called. One is the BRIGHT filament and the other is the DIM filament. DRLs use the BRIGHT filament of the bulb, not the dim ones. When you turn on your headlights, the BRIGHT filament turns off, and the DIM one's come on, you don't need the bright ones at night when you got your headlights on...because their really bright
Does this help? Or did I just confuse you and myself some more?
Old Jun 26, 2003 | 09:45 PM
  #32
slverbullet's Avatar
okay, when you go out to your car next time, turn on your headlights and then turn on your flashers. when the flashers flash on (bright) thats what the DRL's look like. when they flash off, thats the parking lights on normal with head lights on (dim).
Old Jun 26, 2003 | 11:02 PM
  #33
joshp14's Avatar
Gotcha now! Thanks!
blac94Z
Jan 16, 2015 11:03 PM
squarehead
Jan 15, 2015 07:02 PM
CaRParts102
Dec 6, 2014 08:45 AM
Sixer-Bird
10
Aug 25, 2002 01:12 AM
