Cutting Pro 5.0 stick
Old Aug 3, 2004 | 10:33 AM
SantaCruz163's Avatar
Looking at the stick it looks like it is tapered out at the top. For you guys with the Pro 5.0 that cut the stick down are you using your stock **** because if you cut off the tapered top part how did you get it to thread on since it would be too thin?
Old Aug 3, 2004 | 11:28 AM
Bow94z's Avatar
Re: Cutting Pro 5.0 stick
I have the lou's SS with my pro 5.0, im using the stock ball. i wanted to use the hurst shift **** with the H, but everytime i try to screw it on it never comes out straight. seems like there isnt enought thread to make it tight and straight.
i guess thats what you are asking???.....
Old Aug 3, 2004 | 12:58 PM
No...you have a Lou SS. I'm asking guys with the stock stick that comes on the Pro 5.0.
Old Aug 3, 2004 | 03:16 PM
TW95Z's Avatar
Stock ball worked fine after cutting my Pro50. Before making the cut I did put a jam nut on below where I made the cut so when I removed the nut it would deburr any damaged threads.
Old Aug 3, 2004 | 04:18 PM
Robbie's Avatar
I just cut about 1in off the top of my stick. The 5.0 stick has plenty of thread for the **** to fit even with some cut off.
Old Aug 3, 2004 | 07:36 PM
97FormulaWS-6's Avatar
I've done it 2 ways...
Thread a nut on, take the hacksaw to it, then clean the threads with the pre-installed nut.. works decent, not the best method...
Machine Lathe - works the best, but most don't have access to the equipment.
It's not really tapered, I've got over 1" cut off mine and it still threads on perfectly.. and it a awesomely short shift with the MBA billet ball shifter with the recessed threads.
Hoodshaker
Aug 27, 2002 02:32 PM
x7x7
Aug 15, 2002 06:49 PM
jim88iroc305
Aug 13, 2002 09:24 PM
Krab
Aug 5, 2002 12:08 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
