Cutout/Header question
Old Mar 18, 2005 | 01:18 PM
  #16
Z06Z28's Avatar
Re: Cutout/Header question
I ran my cutout with no cats and it was so loud that I couldnt hear my dads Harley Heritage Softail at throttle. I put the Cats back on since the smell was so bad and it actually sounds better with cutout and Cats, smoother. DMH is a nice quality cutout and I like mine but I'd rather just have a nice sounding Catback and not worry about the butterfly valve maintenance and call it a day. Also, geting under the car all the time with no elec plate is a pain in da azz sometimes.
Old Mar 18, 2005 | 04:49 PM
  #17
blind527's Avatar
I still say dump it at the passenger side window or like 10-15 inches back from that
Old Mar 18, 2005 | 05:31 PM
  #18
stew's94z's Avatar
I've got a 3" manual cutout I'm gonna section into my ORP soon. I'll do a open/closed back to back and see how it goes.
Dean
Old Mar 19, 2005 | 01:10 AM
  #19
fredmr39's Avatar
OK - Pacesetter ORY pipe - u know how its smashed for clearance reasons on the drivers side right after the header? For that reason, it looks like it isn't possible (or is difficult/costly) for a shop to weld in a cutout there. rather than dual cutouts, I think I will go with one before the axle bend like my old setup. Then, maybe I can afford electric = )
How much of a volume difference is there between dual and one a little further back? (anyone had both with similar setup otherwise?)
Thanks!
Old Mar 19, 2005 | 12:58 PM
  #20
fredmr39's Avatar
Either way, just o be safe I will go with one. -Any comments on previous post? Thanks!
Old Mar 20, 2005 | 01:14 AM
  #21
93fblt1's Avatar
How loud just running with Y pipe? Will you get ticket for too loud? The reason is I am finishing putting everything back together and with after market exhaust header, Y pipe I will need to drive to muffler shop so they can weld the cat to Y pipe.
Old Mar 20, 2005 | 02:03 AM
  #22
fredmr39's Avatar
I can't imagine THAT dramatic of a difference between that and open headers - especially if Y pipe doesn't have cats like mine. If anything, it may sound better than open headers, and from what I've read, around Y-I connection is best place for cutout.
For Pacesetter ORY pipe tho -- since it is smashed on driver's side for clearance - is it possible to get dual cutouts in there? Also, I'm just getting one - where is the best place for it? At end of y-pipe or start of I pipe, or back more by the axle where clearance is best??
Old Mar 20, 2005 | 08:08 AM
  #23
ShawnMacAnanny's Avatar
my 2 1/2" pipes BARELY clear the transmission crossmemember on the drive side so i dont think you could fit a cutout there. The fuel lines are right there too so that's probably not a good idea to expell ecess heat.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
