Cut out open, bogs off idle
Just installed an electric cut out right before the axle. Now when hard launching off idle it bogs, hesitates, and slight backfire. Once the RPM's are up it's fine. Cut out closed all is well. Not sure where to start. Anyone one else have this problem or know what to look for? I sure can't use it at the track like this.
Found a DTC 23. Could a bad IAT or wire cause the car to stumble/backfire then take off and run normally? If I hold the throttle open just slightly and nail it it takes off fine. It's only from a closed throttle idle that it happens.
Victor Lamb
Aug 26, 2017 02:52 PM
stockssn2o
May 25, 2015 08:54 AM
charchri4
Apr 14, 2015 06:40 PM
SMO Q
Feb 11, 2015 07:13 AM
