to cut oil pan gasket or not?
Old Jan 28, 2004 | 12:51 PM
30thannZ28's Avatar
I'm currently trying to put a new felpro (blue) oil pan gasket in and I'm having all kinds of trouble trying to shimmy it under the rods. There is VERY little space between the bottom of the pan and the internals. Who on this board has had success in simply cutting the gasket and using some ultra copper or black RTV to reseal it? I want to hear everybody's stories god or bad. I really don't want to drop the k-member, so I'm looking for the easy way out.
Old Jan 28, 2004 | 12:57 PM
turbo_Z's Avatar
When I installed a new cam in my motor I ended up tearing the front of the OP gasket off. After several hours putting everything back together I didnt feel like dropping the pan to replace the new gasket I had so instead used some of that black gasket maker RTV. Now probably 6000 miles later it is still not leaking a drop. Some guys say do it right.. I say do whatever works.
Old Jan 28, 2004 | 01:02 PM
MRCAIN's Avatar
I had no problem, just remove the bolts on the motor mounts, and lift the moter up about 3 inches, i do believe the position of the crank makes a difference as well.
Old Jan 28, 2004 | 02:51 PM
I would try to leave it as one piece, since part of the reason they made it one piece was to keep it from leaking.
Old Jan 28, 2004 | 04:02 PM
gb95zconv's Avatar
When I put the hotcam in my old setup I just cut the gasket where it went around the timing cover and used RTV when I put the cover back on and it never leaked a drop.
Old Jan 28, 2004 | 11:53 PM
Lt1t56's Avatar
Do not cut the gasket...... place the gasket around the outside of the pan, opposite if the sealing surface. Then work the gasket around the lip of the pan onto the sealing surface. Worked great for me and gasket goes over pan lip easy since it flexes due to being rubber.
Old Jan 29, 2004 | 08:46 AM
30thannZ28's Avatar
Man, I never even thought of that! I'm going to try it. Brilliant. I will let you guys know how it turned out. Thanks a lot!
Old Jan 29, 2004 | 09:19 AM
wannabeZo6's Avatar
ya lol, i tried doing the same thing u r now, then read somewhere about going on the outside of pan, had teh gasket installed in 2 minutes (no joke) good luck with it
Old Jan 29, 2004 | 09:21 AM
97Camaro007's Avatar
Yeah i did mine by going around the outside of the oil pan...worked like a charm only thing was that you had to cut the oil dipstick hole so that the dip stick will fit...or just remove it and put it back in....either way will work....
Michael
Old Jan 29, 2004 | 10:42 AM
TUFF LT1's Avatar
Yea, I went around the outside of the oil pan too and it went right on. Easy as pie!
Old Jan 29, 2004 | 11:45 AM
Red_94Formula's Avatar
u guys are nuts for not dropping the k-member. thats the only way i could do it. How did you get those crazy bolts out?
Old Jan 29, 2004 | 09:11 PM
30thannZ28's Avatar
Just to let everybody know, I got the gasket on without cutting anything at all and it went RIGHT over the lip from underneath. No problem. It took all of 30 seconds to do. Man, I feel bad for everybody on the board who had to drop the k-member. I wouldn't do it that way. (Course, I had my headers, y-pipe, dipstick, and heads off when I did this, and THAT helps )
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
