custom fuel rails?
Old Aug 14, 2003 | 01:18 PM
chucks97ss's Avatar
custom fuel rails?
Any ideas? Need -10 in and -6 return. Unless you all think the stock rail can handle 650-700 hp n/a?
Chuck
Old Aug 14, 2003 | 01:21 PM
My setup is good for 1,000HP. Single -6AN supply line from the pumps to the back of the engine, split through an NOS "Y" into a -6AN line into the back of each rail. Return is taken off a -6AN fitting welded to the diagonal crossover pipe in the front of the rails, -6AN return line to an AFPR under the cowl, -6AN line back to the tank.
For over 1,000HP, go to an -8AN supply line, and put a -6AN return on the front end of each rail. Y into a single AFPR.
Old Aug 14, 2003 | 01:23 PM
chucks97ss's Avatar
So you just modified your stock rail to accept a single -6 inlet? Do you by chance have a pic?
Chuck
Old Aug 14, 2003 | 02:18 PM
blueirocz-28's Avatar
here's a good example. this is Tracey Scott's car of Cincy.
custom fuel rails 1.
]custom fuel rails 2
done by Scott Racing and Performance www.ts-performance.com
Old Aug 14, 2003 | 02:34 PM
Kind of hard to see the backs of the rails:
AFPR under cowl, fuel pressure sensor on rail
Return line off diagonal cross-over pipe
FPR under cowl, -6AN into rails
-6AN on driver's side rail
Looks a little different on an engine with full emissions....
Old Aug 14, 2003 | 02:45 PM
speedmiser's Avatar
Hey, that's pretty close to my new setup:
http://images.cardomain.com/member_i...0_179_full.jpg
ad356
Apr 16, 2015 05:38 PM
dfarr67
Apr 10, 2015 07:44 PM
4586
Feb 13, 2015 09:16 AM
Jul 4, 2005 05:00 PM
Wilson
Jul 21, 2002 05:08 PM
