custom engine lifting bracket, check it out!
yeah my belt still flys off around 6500 7k....the 5 ribs last a bit longer the 6 rib doesen't.....i've tried all sorts of stuff, If you figure something out let me know....the way mine is set up I use a 35 1/2" belt.....I have considered spacing it out more and running some deep V belt pulleys
Before I took the motor out I ran it to 6500 and I threw the belt once. A few weeks later I poped the hood after a race and saw the belt sitting 2 ribs over. I started to investigate and found that it was tweeking towards the front of the car on a acceleration.
I will have to see if this works. I did notice I had an alignment problem but I am using a smaller 6 3/4" balancer from the vette. Its lighter and smaller so I ended up with a 34.5 belt I think. I also ended up cutting down the spacers and adding a washer between the bracket and alternator to set it back a bit. It was the only way I could get alignment right. The balancer itself is different because I used a Cloyes double roller and the spacer behind the damper. I think it sits bak some compared to stock... Hopefully it will work. If it doesnt I am going to make my own spacers... I think the aluminum spacers in the SJM kit are too wimpy. Either way I will just make something so it works.
Thats part of the joys of racing. I know there will be bugs to work out with the car and set up. If the belt flying off is my biggest problem I am going to be very happy.
BTW, if someone wants to do me a huge favor I wont be mad. Go out and measure the distance from the top of your intake to the cowl and let me know what ya got. I'm just not sure my bracket is going to be low enough.
I made it a tad tall I think. I have room to lower it down. I did that on purpose so I can make adjustments later.
I hope it works, too. I pulled my heads before removing the block, and then it was easy. But I still had to tilt the block a little to clear the cowl due to the reach and ongle of my cherry picker. If yours is longer than the standard AC Delco hoist, maybe it will go in level, even with the heads on. I figure it is going to be easier to put the heads on in the car than wrestle the entire engine in assembled, but I'm rooting for you to show an easier way!
with the amount of work I had to do it was much easier to build it on a stand.
When I took the motor out I yanked it with the intake off. But I did pull motor and trans together out the top. Motor is going back in by itself. I am sure I will have to tilt and twist but once I am below the cowl I should be home free. I'll let you know this weekend
Frank if it works I'll send it down to ya
In regards to the SJM alternator relocation bracket, My aluminum spacers were also too long but I wanted to run a 5-rib belt as opposed to the 6 rib that they supply. I acutally stacked an extra washer behind the bracket to push the alternator forward of the crank pulley. I have the 5 rib belt on the forward ribs on the crank pulley and the rear ribs on the alternator pulley. I raced mine last season like this and I haven't had the belt jump once. 7000rpm shifts btw.
Hopefully I will have room... we will see.
You might want to get a Happy Hooker through TPIS for removal/installation of your motor in an F-body.
I got one and I find it very simple for removal/installation. but than again I have an Impala SS.
I do know this product was made for the f-body.
I'm too cheap... If this doesnt work I'll steal a piece of metal from the scrap bin at work and make one just like that
I believe the HH was made for an F-bod actually...
I havent tried it yet but I did measure the bracket. Its 2.5 inches off the top of the intake to the top of the cross brace of the bracket. This is good news. I will let you guys know if it works soon... maybe tonight.
squarehead
Nov 21, 2014 08:02 PM
94z28jbw
Sep 8, 2002 03:22 PM
danielbmx
Aug 27, 2002 11:11 PM
newby
10
Jul 27, 2002 11:39 AM
