Too cold of a plug
Old Mar 16, 2007 | 12:05 AM
lt1 kenobi's Avatar
Too cold of a plug
Ok, tried this in the nitrous section.. now I'm gonna ask the motor guys.. since my problem is only at idle and super duper light load.. Ok.. I started spraying on my lt1... have msd opti, msd coil, msd wires, mallory box... Everything fine.. put in the autolite 104's gapped at .035.. and I have a slight miss like its loading up at idle... and at super light throttle usually around 2k rpms.... Any remedy that will allow it to still be safe on the bottle as well.
Thanks in advance.
Old Mar 16, 2007 | 12:41 AM
Zeueses 97 RamAir's Avatar
same here
I had the ac delcos on mine plats I was getting a miss at idle, its your plugs the gap is off i changed the plugs friday and put ngk trs55 and presto no miss...
Old Mar 16, 2007 | 02:47 AM
Joe B's Avatar
Thanks in advance.
That's strange....Autolite 104's are only about 1/2 to 3/4's of a step colder than the stock heatrange plugs....and even the colder Autolite 103's (gapped tight at .035) should run just fine on an LT1 motor without causing any loading up or missing issues at all.. Matter a fact, I've never even seen going to the colder Autolite 103's cause what your describing(no less with the 104 plugs and all the better than stock ignition products that your running) it's like maybe something's off with the tune (or a sensor) at that particular RPM where your getting the slight miss, Ect.........I would data log it if you can, or get it on a wideband to see exactly whats happening.......also make sure it's not something simple like a plug wire (broken inside or not fully connected) since you say it happened right after the plug swap.......good luck with it..........Joe
Old Mar 16, 2007 | 06:42 PM
lt1 kenobi's Avatar
Any other ideas??
Old Mar 16, 2007 | 06:45 PM
mdacton's Avatar
try some different plugs and see what it does
Magenta_Hearts
Mar 29, 2017 08:54 PM
markzzzz
May 8, 2015 09:21 AM
greenzee28
Mar 26, 2015 09:13 AM
armedtrigger
Feb 24, 2015 08:30 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
