curious hot cam questions.
Old Feb 15, 2007 | 02:49 AM
06lingenfelter's Avatar
i want to have an idea on horsepower, torque, and track times. ok so i just put in the LT4 hot cam kit, cam, lifters, hardened pushrods, 1.6 rocker arms, springs, new GM lifters, i also have the K@N cold air intake, aftermarket MAF, 52mm throttle body,flowmaster muffler (40 series), high flow cat. and aftermarket y pipe,3.42 gears, soon to be tuned by PBJ (performance by joe) in st.louis, 18 inch Z06 rims, and keep in mind it will be reving to 6,100 RPM. if you have any ideas please let me know. thanks guys!
Old Feb 15, 2007 | 06:21 AM
SnakeOiler's Avatar
M6 or Auto?
Look at sig.
Old Feb 15, 2007 | 06:22 AM
Steve0's Avatar
After you get it tuned, if your car is a 6 speed you should be putting down anywhere between 330-340hp to the rear wheels on a dynojet. I put down 322rwhp/333rwtq without the 1.6 rockers. All dynos are different though...
With that power and a full weight, stock suspension car you should be able to go bottom 13s pretty easily, and top to mid 12s if you can hook well. You're about as fast as a bolt-on LS1.
You might be able to pick up a few horsepower by running a cutout before your muffler.
Old Feb 15, 2007 | 12:10 PM
2000GTP's Avatar
I would guess you would be in the 320ish range and be somewhere in the upper to mid 12s. You may consider upgrading your exhaust down the road to a good set of headers and a decent catback.
Old Feb 15, 2007 | 11:48 PM
manual 6 sp. i already had it dynoed at 302 hp 313 tq. if that helps.
Old Feb 16, 2007 | 06:37 AM
SnakeOiler's Avatar
1) You dynoed @ 302hp before the HOT cam kit?
2) Are you running stock exhaust manifolds?
3) Were you running some other non-stock cam when you dynoed @ 302?
Old Feb 17, 2007 | 05:04 PM
it was w/the stock cam, springs, lifters, and pushrods. i am running manifolds. all i had done when it was dynoed was full intake, high flow y pipe, and cat. so now i have the Lt4 hot cam kit. cam, springs, lifters, hardened pushrods, 1.6 rocker arms. and im going to get it tuned.
jj_burchiel
Mar 5, 2015 07:05 AM
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Smokn '94 Z
Aug 4, 2002 06:11 PM
Smokn '94 Z
Jul 28, 2002 02:38 AM
