Cross Thread Header Bolt
Old Jan 8, 2010 | 04:18 PM
95mysticta's Avatar
Well doing my lt install and got all the bolts in with ease till i got to the last one so i tightened up the rest of the bolts so it would make the header sit flush against the head and it would hopefully thread in. Unfortunatly it would not thread in. Took me a bugger or a time to get them all in to find out that i probubly cross threaded the last thread. Can i do without the one bolt and hopefully not have a leak? Its the bolt on the 3rd primary tube so its got clamp force down on each side of the one missing. Would be a bitch to have to yank out the header after getting this far into it.
Old Jan 8, 2010 | 04:39 PM
RamAir95TA's Avatar
There's no reason you shouldn't be able to run a tap through it. I stripped two of mine on the car and tapped them with no problems.
Old Jan 8, 2010 | 04:46 PM
95mysticta's Avatar
Im going to buy a thread tapping set tomorrow morning and hopefully i can fix it and not have to pull the header off. Might be tricky its awkward to get at on the 3rd primary tube.
Old Jan 9, 2010 | 05:26 PM
95mysticta's Avatar
Well problem solved... bought a tap set and got it fixed and feel way way better about it! Going to re-tap all the threads on the other side before i put the header in for re assurance.
Old Jan 9, 2010 | 09:50 PM
brucer's Avatar
wouldnt studs be better after you get the holes cleaned out..
Old Jan 10, 2010 | 09:00 AM
Kevin Blown 95 TA's Avatar
Yeah studs for questionable holes (actually I have studs on all of them) and don't run a tap in there, use a thread chaser. The tap will likely take out metal and your threaded holes will be looser and more likely to strip at some point. A thread chaser gets the gunk out of the threads but doesnt have any cutting action.
Old Jan 10, 2010 | 11:23 AM
brucer's Avatar
yep im a too&die maker.. was just adding to the thread (sarcasm )...
i have to get a broken bolt out of one of my heads and i'm contemplating just going ahead and putting thread inserts in while i'm at at so i dont have any trouble with the threads later on..
Old Jan 10, 2010 | 03:05 PM
Originally Posted by brucer
delete this:
i dbl clutched the post button
use the edit button then delete your own post.
Old Jan 10, 2010 | 06:04 PM
95mysticta's Avatar
It was only the first thread or two that was damaged. I will keep an eye on it and make sure and if i have to put a stud in place i will.
Thanks!
Old Jan 11, 2010 | 10:28 AM
Z28SORR's Avatar
NEVER tighten any bolts before you start all of them. Don't know why more people don't drill these header bolt holes out, one or two bit sizes before they install them. It's so much easier then fixing cross threaded holes.
Old Jan 11, 2010 | 01:31 PM
NJ-LE's Avatar
As Z28SORR wrote ... good advice:
Also, if the header has separate mounting flanges (ie MAC), hold the header gasket up to them to be sure that the shipping agent didn't "adjust" the spacing for you! Check and adjust any warpage with a straight edge or long level on the flange face too.
Victor Lamb
Aug 26, 2017 02:52 PM
Richardan15
May 30, 2015 08:36 AM
maybe2fast
Mar 16, 2015 09:45 AM
moparman
Feb 11, 2015 08:29 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
