crankshaft sprocket removal
Old Oct 20, 2007 | 03:49 PM
southern78's Avatar
95 Lt1 Camaro
I am trying to remove the crankshaft sprocket and have a 3 jaw puller but was wondering is there a key or something that needs to be removed before I can pull the sprocket off? The sprocket appears to have a notch on it. I was just wondering.
Old Oct 20, 2007 | 03:51 PM
dangalla's Avatar
just pull it off, the key should stay in the crank, but it may fall out
Old Oct 20, 2007 | 03:59 PM
southern78's Avatar
So no need to worry about the key or anything just pull it off with the puller? Just didn't want mess anything if I cranked down on the puller to get it off.
Old Oct 20, 2007 | 04:00 PM
dangalla's Avatar
it should come off with not much trouble at all
Old Oct 20, 2007 | 04:14 PM
southern78's Avatar
THanks..got it.
Old Oct 20, 2007 | 04:19 PM
Dawgz83944's Avatar
If you are taling about the pulley then it slides right off. If your talking about the thing that holds the pulley onto the crank then it requires a special puller with a steel tube that goes into the crake hole. If you are thlking about the timing sprocket that just comes off with a 3 jaw puller without too much grief.
War Engine
Aug 28, 2015 06:04 AM
Slayer
Aug 17, 2015 03:55 PM
4586
Jul 31, 2015 06:03 PM
mrwz28
Jul 8, 2015 09:11 PM
SergheiS
Jul 5, 2015 03:27 AM
