Crankshaft hub from a 96+ fit on a 95?
Old Jul 9, 2005 | 12:08 PM
Black1995Z's Avatar
Possibly clearance issues??
I am looking to get a new one and decided to be on the safe side before i bought one.
If a 96 wont work on my 95 (misfire reluctor) which years will?
Old Jul 9, 2005 | 12:56 PM
Dave89IROC's Avatar
Re: Crankshaft hub from a 96+ fit on a 95?
96+ is shorter due to the addition of the CPS reluctor, you need a 93-95 F-Body hub(not Y-body[vette], not B-body[caprice, roadmaster, ect.])
Old Jul 9, 2005 | 02:40 PM
Z95m6's Avatar
Ditto, Ask me how i know that one.
Old Oct 1, 2005 | 09:52 AM
Jim D's Avatar
Why not a B-body hub?
I have a donor engine from a Caprice but put different internals in there (Scat crank and rods, Probe pistons). Since it came from a Caprice, I guess I should stick with a Caprice hub....is the difference the way it lines up with the pulleys?
Old Oct 1, 2005 | 10:11 AM
96capricemgr's Avatar
The difference is in the accessories not the engine so use the correct hub for YOUR CAR not the donor car.
Old Oct 1, 2005 | 10:40 AM
Jim D's Avatar
OK, thanks for the quick reply. Guess I will have figure out which to use, I am putting this into an 86 IROC so it is taking me a little while doing all the "homework" as I go.
Thanks again for the quick answer!
Old Oct 1, 2005 | 01:39 PM
Dave89IROC's Avatar
use the hub and damper to match the accessories, the B-body acccessory bracket is a little deeper then the f-body one, and vette is also different
HectorM52
Jul 30, 2017 11:46 AM
mschmidt33
Mar 15, 2015 07:20 PM
cyteone
Feb 7, 2015 06:04 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Camaro_Eric
Aug 8, 2002 12:21 PM
