Crank timing gear
Old Jun 16, 2008 | 03:02 PM
ShownomercyZ28's Avatar
Crank timing gear
How do you guys get the gear on the crank?
Old Jun 16, 2008 | 03:16 PM
ZL1modified's Avatar
i was wondering the same thing yesterday when i put mine on... i kept asking myself "can i heat it up and tap it on?" and i didn't have a gear installer so i grabbed the propane torch, baby sledge and a piece of wood to use as a drift...
took a little while but i got it all the way on...
not sure if this was the correct way, but i did do an online search and saw that it is a method that has been used...
Old Jun 16, 2008 | 03:19 PM
http://shbox.com/ci/crank_sprocket.jpg
A little oil will help it go on.
Old Jun 16, 2008 | 03:42 PM
Yup I saw that but I was wondering what the tool is?
Old Jun 16, 2008 | 05:46 PM
cnorton's Avatar
The tool is basically a piece of pipe with an inside diameter a little larger than the outside diameter of the crank snout and woodruff key. It has a closed end or a cap welded over one end. Such a tool is included in the kit when you buy a Jesel Belt Drive.
Old Jun 16, 2008 | 11:16 PM
fnsblum@comcast.net's Avatar
Lay the gear on a 100 watt bulb for 3 or 4 minutes. It will slide right on. This works well on bearings also. Later! Frank
HectorM52
Jul 30, 2017 11:46 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Noenav
Dec 6, 2014 07:35 PM
1LEThumper
Jul 14, 2003 12:45 PM
