crank snout removal???
Old Dec 30, 2003 | 04:48 PM
reuter's Avatar
Angry crank snout removal???
hey i got the harmonic balancer off and am ready to pull the timing cover. so i get a harmonic balancer puller to pull the crank snout and this thing WILL NOT BUDGE. i torqued it so hard it even started to bend the puller's bolts. impact wont work, cheater isnt helping. what gives? am i missing something here?
Old Dec 30, 2003 | 04:55 PM
AsianSensation's Avatar
I put a 1/4" extended socket in the hub so the harmonic balancer puller can push off on that instead of on the hub itself. If you have not already done that.
Old Dec 30, 2003 | 07:32 PM
97WRAITH's Avatar
I used a grade 8 bolt to push off of. and it worked but it was a PITA! keep trying don't give up.
Rob.
Old Dec 30, 2003 | 08:58 PM
You are probably trying to pull the hub apart, since it is made like this. It's not the same as removing a balancer from a regular SBC. You have to use something down the hole to push against like previously mentioned.
REDNECKISBOSS
Mar 22, 2015 08:31 AM
jj_burchiel
Classic Engine Tech
Mar 13, 2015 11:20 PM
Chevyguy358
Jan 28, 2015 08:04 PM
1LEThumper
Jul 14, 2003 12:45 PM
