Crank shaft sensor?
Old Oct 31, 2009 | 12:45 PM
henryz28's Avatar
Crank shaft sensor?
I went to a dyno shop today the dyno guy said I need a crank shaft sensor on my 1996 camaro. He said it will not set the timing correct; but I thought on my obd2 car the only thing that sensor was for was detecting miss. Does the sensor have any affect on performance? Who is full of **** me or him.?
Old Oct 31, 2009 | 03:31 PM
henryz28's Avatar
I think I am right, on a obd2 lt1 the only thing the csp sensor is for is miss fire detection. The opti controls all spark and injection on a obd2 lt1. I tried to tell the dyno guy that but he thinks he is correct because he has 40yrs experience. He thinks my timing is off because of the deleted crank shaft sensor; I think he is incorrect. We talked about it for 30min and I ended up agreeing with him to end the argument.
Old Oct 31, 2009 | 03:44 PM
Stl94LT1's Avatar
You're right, he's wrong!!
Old Oct 31, 2009 | 03:56 PM
henryz28's Avatar
He is trying to tell me it cant be dyno tune with out the crank shaft sensor. Has any one dyno tuned there obd2 lt1 with a deleted crank shaft sensor or can it be done? He also wants $650 for the dyno.
Old Oct 31, 2009 | 10:26 PM
Go somewhere else.
Old Nov 1, 2009 | 12:16 AM
henryz28's Avatar
Originally Posted by shoebox
Go somewhere else.
That was my decision after speaking with him. He was a good guy, but he is one of those jack of all trades master of none guys. I think west coast corvettes is going to be the best choice for a dyno here in So Cal.
Old Nov 1, 2009 | 09:49 AM
You can NOT tune an LT1 with only a CRANK position signal. In fact it can't run on the crank position, because from 94-97 the engine uses sequential injection.
To sequentially fire the injectors, you need a CAM position signal. The cam position signal comes from the optical sensor in the Optispark - the low resolution pulse signal. Once you know the cam position, you also know the crank position, but that's no longer important.
That does not work the opposite way.... knowing the crank position, you still don't know the cam position, so with a crank sensor, you can not run sequential fuel injection. You have to run batch fire, or bank-to-bank.
Old Nov 4, 2009 | 10:22 AM
sconley1028's Avatar
If the crank position sensor is bad will the car run at all??
Old Nov 4, 2009 | 10:26 AM
RamAir95TA's Avatar
Yes. It is only used for detecting misfires.
Old Nov 4, 2009 | 10:45 AM
Sure.... 93-95 LT1's run just fine without a crank position sensor. To repeat... the crank position sensor was added in 1996, for the sole purpose of meeting the OBD-II requirement of identifying misfires. IT IS NOT USED TO RUN THE ENGINE!
Victor Lamb
Aug 26, 2017 02:52 PM
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 07:28 PM
VF-124
Mar 16, 2015 08:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
