crank key moved when putting on hub
Old Jul 22, 2008 | 08:18 PM
ascastil's Avatar
i was putting the hub back on the crank and it must not have been sitting right cause the key was forced up and back. nothing was damaged but now wtf do i do about this key? can it be removed or hammered back into place? suggestions please!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jul 22, 2008 | 08:24 PM
BCdawg57's Avatar
The hub is not keyed on an LT1.
Old Jul 22, 2008 | 08:27 PM
96' Formula WS6's Avatar
yea as bc said he crank is cut for a key but there is no key on the hub.
Old Jul 22, 2008 | 08:32 PM
ascastil's Avatar
then what is the metal tab that is sticking out of the crankshaft and how do i get it back down
Old Jul 22, 2008 | 08:44 PM
BCdawg57's Avatar
A picture would help.
Old Jul 22, 2008 | 09:06 PM
ascastil's Avatar
this tab that i speak of is shaped like a half moon, i took it out of the crank, can i put the hub on without it
Old Jul 22, 2008 | 09:09 PM
BCdawg57's Avatar
The only thing i can figure that you are talking about is a part of the crank position sensor. I dont know what year your car is but if it is OBD II then that might be what you are talking about, and in that case you definatley need to keep it there. Other than that, you just need to press the hub on to the crank snout, positioning doesnt really matter, as the pulley is not a balancer, but more of a dampner.
Old Jul 22, 2008 | 09:27 PM
ShownomercyZ28's Avatar
Or the timing chain key...
Old Jul 22, 2008 | 09:31 PM
ascastil's Avatar
my car is obd2 and so thats what it is a crank position sensor, that makes sense. i took the timing cover off and hamered it back into place and tried again with no luck, the hub just keeps pushing it back. would a slotted hub from thunder racing work, is that what that slot is for?
Old Jul 22, 2008 | 11:06 PM
ulakovic22's Avatar
There are 2 keys for the LT1 crank and 2 hubs as well. The key for OBD2 has a larger raised portion to key the timing chain as well as the reluctor wheel for the CPS. OBD2 hub is also shorter because of the reluctor wheel. OBD1 doesn't have a CPS/reluctor so the key is shorter and the hub is longer. Make sure you have the correct combination because the hub isn't suppose to touch the key.
Old Jul 22, 2008 | 11:48 PM
If you are putting a key in the front slot-don't (unless you have a keyed hub). Only a special cut-back key is required (in the rear slot) for the crank gear.
Old Jul 23, 2008 | 08:02 AM
ulakovic22's Avatar
Did you recently get the engine rebuilt? A lot of places will use a key in the front slot so they can rotate the motor over while working on it, maybe they forgot to take it out.
Old Jul 25, 2008 | 11:09 AM
ascastil's Avatar
i did have the motor rebuilt. i took the key out and the hub went on perfect. thanks to everyone for their help.
PCLZ28
Dec 24, 2015 05:19 PM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
1LEThumper
Jul 14, 2003 12:45 PM
