Cracked radiator reserve
Old Dec 2, 2009 | 02:44 PM
Cliffburton99's Avatar
96 z28 camaro. Ive been losing a lot of coolant and I removed my radiator reserve and noticed it has a crack underneath the battery tray. When I looked there was no fluid but its an obvious crack. Can fluid be leaking here without me noticing? Also the lower radiator hose was colapsed, what could be the cause of this?
All help is greatly appreciated.
Old Dec 2, 2009 | 03:22 PM
n2ceptor's Avatar
The reserve you can get at your local dealership... Cost around 25 dollars when I picked up mine... As for the lower hose, how old is it???? Might be worn...
Old Dec 3, 2009 | 04:53 AM
The hose collapses when the system cools down, and pulls a vacuum. The cap should relieve the vacuum, pulling replacement coolant from the reservoir. Appears you may have a problem with your cap, as well as with the reservoir.
David Dempsey
Mar 12, 2016 12:42 AM
IndyZman
Oct 22, 2015 02:17 PM
Daluchman1974
Sep 11, 2015 06:12 AM
scottcba1
Sep 8, 2015 09:52 AM
Pwilson59
Sep 3, 2015 08:47 PM
