cr on pump gas
Old Dec 21, 2006 | 06:21 PM
osolow's Avatar
cr on pump gas
how much compression can i run on a 6''rod 381 and still use super unleaded? I will probly be running an le4 or gm 847 if this matters.
Old Dec 21, 2006 | 07:59 PM
osolow's Avatar
any1?
Old Dec 21, 2006 | 11:12 PM
grammerman's Avatar
Search for DCR or dynamic compression ratio. Conservatively you might want to stay around 8.5:1. There are DCR calculators (google it) that will take specs from your cam, engine and your static compression ratio and estimate the DCR. I'd guess that static compression might somewhere between 11 and 12:1 but DCR is what you really need to figure out.
Old Dec 21, 2006 | 11:43 PM
Wild1's Avatar
Absolutely, it's all about the Dynamic Compression Ratio. You can find calculators on the internet, I like this one.
http://www.empirenet.com/pkelley2/DynamicCR.html
The article talks about thresholds between 7.5 and 8.5 but that is for non-reverse cooled heads. With an LT1 you can be safe around 8.5 to 9.0 (limit pending gas quality)
ad356
Apr 16, 2015 05:38 PM
Magenta_Hearts
Mar 22, 2015 03:36 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
simple
Aug 11, 2002 11:56 AM
dmaastr
9
Jul 1, 2002 02:22 PM
