Couple ?'s
Old Jan 3, 2004 | 08:30 PM
smokerZ28's Avatar
Couple ?'s
What is the CC on a stock LT1 piston and how much compression can I get away with using the CC306 on pump gas? Also what head gaskets should I use fel-pro, anything else?
Old Jan 3, 2004 | 08:47 PM
Josh-'04 GTO's Avatar
Re: Couple ?'s
With the CC306 you should be able to run 11.5-11.8 static compression ratio with 91 or better octane with out any knock issues.
I chose to run the Impala SS gaskets for a little extra compression due the smaller compressed thickness (.029") vs. stock or Felpros.
Old Jan 4, 2004 | 02:26 AM
smokerZ28's Avatar
thanks man, what about the CC on the piston, anyone?
Old Jan 4, 2004 | 02:47 AM
97WS6SCharged's Avatar
It should be a 4 valve relief flat top piston with 58 cc chambered heads. If I recall correctly anyway.
Sep 27, 2015 01:55 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
Slayer
Aug 17, 2015 03:55 PM
Aug 17, 2015 09:50 AM
