Couple ?'s
Couple ?'s
What is the CC on a stock LT1 piston and how much compression can I get away with using the CC306 on pump gas? Also what head gaskets should I use fel-pro, anything else?
Re: Couple ?'s
I chose to run the Impala SS gaskets for a little extra compression due the smaller compressed thickness (.029") vs. stock or Felpros.
Aug 17, 2015 09:50 AM
