a couple problems with my new setup..
Old Sep 10, 2007 | 08:37 AM
  #16
Originally Posted by fireman
24lb SVO injectors will be fine. Its more like 28lb at the LT1s fuel pressure. You can do 30s as well.
You will need a tune though. Grab a mailorder tune after you swap the injectors so you can drive it around. I highly doubt NicD will tune your LT1.
Good luck
The flow increase due to the different fuel pressure is only about 5%. At 43.5psi, the SVO's flow 25.3 #/HR. The stock LT1 injectors are programmed at 24.9 #/HR..... not any real difference between them.
If you want to keep the duty cycle under 85%, you can't push the stock LT1 injectors over about 355 flywheel HP. Sounds like he should be closer to 32 #/HR (depends how many yadas he actually installed).
Old Sep 10, 2007 | 04:15 PM
  #17
fireman's Avatar
You are correct, I was thinking of LS1 injectors.
Old Sep 10, 2007 | 04:17 PM
  #18
An LS1 injector will flow less when you run it at 43.5psi, not more.
Old Sep 10, 2007 | 04:59 PM
  #19
fireman's Avatar
Yes, but an LS1 injector is 28lbs on an LS1, thus putting the magic number 28 in my head where a 25 should have been...
my mistake, you are correct as always
Old Sep 10, 2007 | 08:56 PM
  #20
Irish350's Avatar
hahaha... i guess it would make sense to go over all of the yaddas..
k&n fipk, 58mm bbk TB, pacesetter LTs, borla catback, U/D pulley (with alt O/D), CSR EWP, 1.6 rrs, stage 1 port pros heads, 230/236 .544 .555 114 cam and madz tune...
im pretty sure i covered everything... what kinda hp/tq do you figure thatll put me at?
and what would be the proper size injectors to get and can you go too big?
Also, should i go with an aftermarket fuel system (racetronix)?
can anyone think of any other reason the fans wouldnt turn on?
Old Sep 11, 2007 | 08:16 PM
  #21
Irish350's Avatar
tutor tap..?
Old Sep 12, 2007 | 12:42 PM
  #22
I'll guess 430-450 flywheel HP... but I have no idea what "stage 1 port pros heads" are.
and what would be the proper size injectors to get and can you go too big?]
Multiply your estimated flywheel HP by 0.07 to get the minimum injector size.
0.07 X 450 = ~32#/HR
If you think you are closer to 500 flywheel HP, try:
0.07 X 500 = ~35#/HR
You can not go too large, as long as you don't get ridiculous. Running a 36# or a 42# injector won't hurt at the 450HP level, as long as its tuned for the correct injector size.
Yes
What temperature did madZ28 set the fan on/off temps at? Have you checked the reading of the coolant temp sensor in the water pump housing, using a scanner?
Old Sep 12, 2007 | 09:34 PM
  #23
Irish350's Avatar
here are the specs port pros website gives for the stage 1 head setup:
Stage 1
Stage 1 Port work with flow sheets
1.940 Port Pros stainless steel swirl polished intake valves
1.500 Port Pros stainless steel swirl polished exhaust valves
Port Pros hydraulic valve springs
5-angle valve job-set valve stem heights-set spring installed heights-
bronze guide liners -surface-pressure test-new valve seals
Completely assembled ready to bolt on.
the fan problem has been going on through multiple PCMs, so i dont think its a tuner thing, and i havent scanned that sensor, but i will be tomorrow if all goes according to plan.. i found a burnt wire today that goes in the general area as the fan wiring, so that may be my problem
Old Sep 13, 2007 | 08:35 AM
  #24
What flows do they claim? Those are basically small, stock valve sizes.... although that's what LE uses in the LE1 package. Most LT1 peak performance heads will go with at least 2.00 I / 1.56 E. Even the stock LT4 heads went with 2.00 I / 1.55 E.
Old Sep 13, 2007 | 04:44 PM
  #25
Irish350's Avatar
idk, they didnt send the promised flow sheets, even after calling and asking for them.. to be honest, i wasnt too surprised with how much material was taken away either, but i figured im not a porter, idk what im talking about.. and it was such a hassle just to get my parts, that i just said whatever, and put it all back together (its my only vehicle)..
to be honest, i just try not to think about it. lol.
so i just jumpered the ports on the DLC, and my pcm doesnt even turn the fans on... i cant find any burnt wires, and all of the fuses and relays are good...
[edit] so the heads do make some difference.. i ran the car with it hooked up to his laptop and all that tuning goodiness (minus wideband) and it was flowing like 35 gps (?) more than his 353 lt1
Old Sep 14, 2007 | 02:20 PM
  #26
Irish350's Avatar
TTT
does anyone know of any "problem spots" where wires might have been burnt/cut?
i dont see any of these wires/looms going near the headers really.. any other ideas?
edman
Mar 13, 2015 09:39 PM
StansZ28
Feb 19, 2015 07:39 AM
Scottyboy
Feb 11, 2015 10:28 PM
Ryabut98
Sep 3, 2002 11:45 PM
