Couple of LT1 Head ?'s
Old Aug 29, 2004 | 09:19 AM
1FastRedZ's Avatar
How much valve spring pressure can a stock head (LT1) hold safely? Also if the heads have been substantually milled, 52cc combustion chambers, is the base too thin to spray the car hard, 200-250 shot?
Old Aug 31, 2004 | 08:24 AM
Re: Couple of LT1 Head ?'s
As you can see... no responses. If it has "LT1" in the topic, its about 99.9% certain that it belongs in "LT1 Engine Tech". Moving it there.
Old Aug 31, 2004 | 09:21 AM
Fastbird93's Avatar
If you're asking how much valve spring pressure you can run, it's not a matter of the head, it's going to be dependent on the type of lifter you use and the cam profile to dictate the proper springs pressures.
As far as the milling, can't help ya.
parkers Z28
Mar 11, 2016 08:14 PM
oldschool
Feb 9, 2016 09:21 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
