Corvette MAF Sensor for LT1
Old Mar 29, 2009 | 01:13 PM
ISUCamaro's Avatar
Found this link for Corvette MAF for LT1...does anyone else have this and experience the gains that they claim? Thanks
http://www.mamotorworks.com/corvette-3-330-677.html
Old Mar 29, 2009 | 02:15 PM
Depends how much HP you're making. If you're stock, the stock MAF, with screen intact, is more than adequate. If you are making 500+HP, you might see some gains.
Old Mar 29, 2009 | 04:14 PM
ISUCamaro's Avatar
The site claims 9+ HP so regardless that seems to be an increase or better than what I would have...main concern was if it would mess with the car's programming/computer and or air/fuel ratio? I dont pretend to know much about cars but I was just wondering if that would throw anything for a loop?
Old Mar 29, 2009 | 04:22 PM
96capricemgr's Avatar
If you honesty believe all advertisers claims do yourself a favor and do not modify your car atall.
IF they gained that much power it has to do with calibrations not intake restriction.
The stock programming is too rich and the aftermarket likes to try and sell MAFs that lie to the pcm about airflow to trick it into leaning out a little which can gain HP. Thing is that is a completelyassbackwards way to do it and the right way is to reprogram the pcm for the right air fuel ratio.
One good tuner found single digit HP gains on his personal over 500rwhp car by swapping out the stock MAF. For single HP gains on something that nasty your car would see NOTHING if properly programmed before and after. Again though when things like this show gains it is because of improper programming before.
pete53
Dec 9, 2014 07:31 AM
Rich_z28
Sep 13, 2002 03:35 PM
Rich_z28
Sep 8, 2002 12:00 AM
Rich_z28
Aug 29, 2002 11:01 PM
Rich_z28
Aug 29, 2002 10:44 PM
