View Poll Results: How to Correctly Ajust Rocker Arms
Method 1
20.00%
Method 2
60.00%
What's a rocker arm???
20.00%
Multiple Choice Poll. Voters: 5. You may not vote on this poll
Correct Way to Ajust Rockers
Old Feb 1, 2005 | 09:06 PM
Smoke T/A's Avatar
Ok this is going to be a poll to decide what is the best way to aftermarket rocker arms. Just seeing how most people on here do it. I have done it by method 1 for who knows how long.
METHOD 1 1.Turn poly lock with set screw backed out down until drag is felt on the push rod. 2.Hold the nut with a wrench and tighten down the set screw untill it hits the rocker stud. 3. take the wrench and give the rocker a 1/8th of a turn or what ever is needed according to the lifters.
METHOD 2 1.Turn poly lock with set screw backed out down until drag is felt on the push rod. 2. Turn the nut 1/8th of a turn. 3. tighten down the middle set screw and your done.
Thanks for your time!!
Joe
Old Feb 1, 2005 | 09:22 PM
93LT1355's Avatar
Re: Correct Way to Ajust Rockers
I used method 2 when I installed my new roller rockers last weekend and it worked.
Old Feb 1, 2005 | 09:26 PM
MentalCaseOne's Avatar
I have new oem lifters so I went to almost half a turn.. then tightened the set screw and gave the whole poly/set screw convo and additional squeese till I got the perfect half turn...
No problems so far.
Marvin
Old Feb 1, 2005 | 09:29 PM
captaindbol's Avatar
Another vote for your method 2. The set screw is meant to bind and lock the setting of the nut once adjusted, not the other way around. Using method 1 your actually locking your adjustment in with no preload and then forcing the nut a 1/4 turn. That can't be a good thing.
Old Feb 1, 2005 | 09:38 PM
Best is subjective. Both methods listed have been used and worked for people. I don't see a "correct" answer to this question.
I use method 2. Method 1 does not allow you to feel how much pressure there really is on the set screw. I don't like that.
Old Feb 1, 2005 | 11:06 PM
turbo_Z's Avatar
I believe the "best" method is neither of those. Its the one where you set them with the motor running. Takes under 5 minutes to set all of them and is easily as accurate if not more accurate then the other 2 methods.
Old Feb 1, 2005 | 11:11 PM
yes its easy that way... but what if the plunger doesnt get dead centered in the lifter? ah Blah what do I know.
I did one lifter like that and it was easy... by the way I thought he was asking how to tighten the poly locks properly.. maybe I am wrong..
I'll keep checkin on this post .. its interesting..
Marvin
Old Feb 1, 2005 | 11:55 PM
turbo_Z's Avatar
Marvin
Oops. I didnt read that correctly! Yes method 2 is what I use.
Old Feb 2, 2005 | 12:06 AM
stereomandan's Avatar
1/8 turn? If you are using stock lifters, or OEM replacements, you want at least 1/4 turn past zero lash. Once you actually do it, you will realize that this is made out to be a bigger deal than it really is.
Dan
Old Feb 2, 2005 | 04:31 AM
rskrause's Avatar
Moderator
Set the rockers with the motor warm, but the idea that they should/need to be set on a running engine is one that escapes me.
Rich
Nutty's96
Dec 21, 2015 06:25 AM
Wart Hog
Sep 8, 2015 05:53 AM
JCSWS6
Jul 19, 2015 06:47 PM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
94Form
Jul 17, 2015 10:56 PM
