Correct timing
Old Sep 21, 2008 | 07:03 PM
C5042081's Avatar
Correct timing
Well it turns out the timing was off a tooth, I re-did the timing
Hopefully its right this time, does this look correct #6 is tdc
Old Sep 21, 2008 | 08:58 PM
EviLZ28's Avatar
Is that a new chain, It looks loose?
Old Sep 21, 2008 | 09:14 PM
C5042081's Avatar
ya its new, i didnt torque down the 3 bolts yet
Old Sep 21, 2008 | 09:30 PM
Stl94LT1's Avatar
Yeah, looks like you've got it right. But, spin the engine over a time or two by hand, and see if they still align.
Old Sep 21, 2008 | 10:43 PM
Generally helps if you keep the response in the original thread, or at least include a link to your original thread so people know how the problem has progressed:
https://www.camaroz28.com/forums/sho...d.php?t=636087
Did you check Shoebox's timing set animation:
http://shbox.com/1/cam_timing_ani.gif
Old Sep 22, 2008 | 03:52 PM
C5042081's Avatar
update : I rotated the engine 2 full times and the dots line up fine as in the pict. I guess i will see how it works, just waiting til tomorrow for the wp and timing gaskets to get here
Old Sep 23, 2008 | 12:18 AM
87bandit's Avatar
that's what I thought
Old Sep 26, 2008 | 07:26 PM
C5042081's Avatar
well it turns out brand new opti was bad, swaped with another and it fired the 1st shot
InfernalVortex
Jan 17, 2015 09:35 AM
Collector Car
Jan 5, 2015 10:58 AM
Jul 4, 2005 05:00 PM
Lions3
Aug 27, 2002 01:33 PM
Bando
Aug 2, 2002 02:18 PM
