timing off , wont fire
Old Sep 18, 2008 | 04:28 PM
C5042081's Avatar
in the process of putting together a H&C swap , I had a buddy do the timing chain and the opti. To make a long story short when starting the car, it misses and does not even fire right, it wants to start . I have fuel, spark etc.
Would it fire if the timing was off a tooth?
I was also thinking the valves could be too tight?
Old Sep 18, 2008 | 06:12 PM
94SLUG's Avatar
Both are possible how about start easy make sure all the plug wires are in correct order I have blown this several times before....
Old Sep 18, 2008 | 06:13 PM
94SLUG's Avatar
You can check the t-chain by finding tdc and refer to the opti location...
Old Sep 18, 2008 | 07:47 PM
C5042081's Avatar
plug wires are correct, i even tried 2 new sets
Old Sep 18, 2008 | 07:50 PM
C5042081's Avatar
I will pull off the wp next and opti to check it out, I am getting spark but opti might not be working 100%, I got it new but i heard horror stories
Old Sep 19, 2008 | 05:20 AM
Its possible the Opti was not indexed correctly to the cam. But you didn't tell us the year of your car, so its hard to tell if that's the cause. 93-94 use a splined shaft that can easilly be misaligned, throwing the timing off, but allowing it to run poorly if its only off a tooth. 95-97 use the cam dowel, and the Opti can fit three different ways (two of them incorrect), but will generally not even run because the timing is fo far off.
Why not add a "signature" with basic info about your car - year, model, engine, trans and any major mods. Makes it a lot easier for people to help you. All years of the LT1 are not identical in many respects.
Old Sep 19, 2008 | 09:51 AM
C5042081's Avatar
Its a 95-97 vented opti
Old Sep 19, 2008 | 12:15 PM
texas97z's Avatar
I went through this once and made a very stupid mistake and all your symptoms sound just like mine. I had the cam gear off and it did the exact same thing. If you try to start with your foot to the floor it will start(barely) and as soon as you let off it dies. I would start by looking at the cam gear and seeing if he put it on wrong. Sucks but that was my problem.
Old Sep 19, 2008 | 03:33 PM
C5042081's Avatar
yup exact symptoms, barely starts, when given gas it stumbles to stay firing, when i let off it dies, I will check out the timing this weekend
Old Sep 19, 2008 | 10:23 PM
87bandit's Avatar
opti could be installed wrong, plug wires mixed up, valve lash too tight, cam installed off (gasp!)
sounds like when my cam got installed wrong because I trusted a friend aswell
Old Sep 20, 2008 | 07:13 PM
C5042081's Avatar
opti is right, plugs check 3x, lash adjusted 2 times
either bad opti or timing a tooh or two off
Old Sep 20, 2008 | 07:17 PM
pyro719's Avatar
How could the timing be off a tooth? You line up the 2 dot and bam its in time.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Noenav
Mar 1, 2019 07:38 AM
DetroitZ28
Feb 13, 2015 07:33 AM
Noenav
Dec 6, 2014 07:35 PM
