correct running temp
Old Nov 13, 2008 | 03:18 AM
popularguy420's Avatar
I have a stock 1995 z28. it had been running at 180 degrees but for the last couple of weeks it has been getting up to 210 degrees is this normal or could it be my thermostat that is going out? Any help would be greatly appreciated
Old Nov 13, 2008 | 05:12 AM
The stock thermostat is 180*F. It doesn't even start to open until that temperature. Its not unusual for the coolant temp to stay near the middle of the gauge (~210*F) for most driving conditions, with the stock t'stat and stock fan on/off temp programming. Maybe a little lower at freeway speeds, maybe a little higher sitting in traffic on a hot day. If the temperature increase is most noticable at freeway speeds, check and make sure the air dam under the front bumper is still in place.
Old Nov 13, 2008 | 06:53 AM
If you have observed a sudden change in running temp, check for plastic bags or debris that might have gotten sucked onto the front of the a/c condenser.
Old Nov 13, 2008 | 07:04 PM
roadgod's Avatar
operating temp
I just finished install of an electric water pump. The stock pump was 3 years old. It wasn't all the way gone, but would hang, then spurt some coolant from the weep hole. Why most optisparks go out. Anyway, after the new pump, I have driven it in stop and go traffic,on 80 degree days. As long as I have the A/C or defrost on, the first fan will run constantly. Thats how the factory setting is. I haven't seen the gauge go above the 180 degree mark yet. It's a Mezeire HD 50gph pump.
If your running the a/c or defrost, and the first fan is running, you shouldn't be getting too hot. If you are, I would keep an eye on the water pump. Like I said, the seal/bearing on mine was beginning to seize.
DirtyDaveW
Dec 1, 2016 05:37 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
cmdeshon
Dec 27, 2014 10:06 AM
brentbrowning01
Dec 16, 2014 06:35 AM
Jul 4, 2005 05:00 PM
