correct idle speed for M6
ok my car idles at 1000. the scanner says desired idle speed is 800. ive got no codes and nothing is out of line. but should my idle speed be down to 800 or is 1000 fine? thanks trey
The stock programming sets the idle speed at 800rpm, fully warmed up coolant. Mine idled there, +/-25rpm, consistantly. Of course that's reading it from the PCM, and not from the stock tach, which typically read 900-950rpm.
While checking the idle with a scanner, check the IAC counts. They should be in the range of 20-40 counts, varying slightly to pull the idle back to 800rpm. If the IAC counts bottom out at "0" before the idle comes down to 800rpm, you might have the TB blades open too far, or a vacuum leak.
Here's the tables from the PCM:
COOLANT----- A4-------A4----------M6
TEMP----------IN---------IN
deg F--------GEAR----NEUTRAL
-40 degF-----800------1200------1200
-19degF ---- 800------1200------1050
3degF---------800------1200------1050
24degF-------800-------1000------1000
46degF-------800--------950-------900
68degF-------800--------900-------900
89degF-------800--------900-------900
111degF------800-------900-------800
132degF------750-------850-------800
154degF------650-------750-------800
176degF------550-------650-------800
>176degF-----550-------650-------800
Originally posted by jasons93z
It should go down to about 800rpms when warm
So if it doesn't, what does that mean?
I bought the car 4 years ago like that and it's never changed
As far as I know, the factory tachometers usually read about 200 RPM's higher than the actual RPM's. My tach shows 1000 at idle but when hooked up to a scanner it's actually idling at 800. Just some food for thought.
Jul 4, 2005 05:00 PM
