correct idle speed for M6
Old Aug 14, 2003 | 09:52 PM
TA Dreaming's Avatar
ok my car idles at 1000. the scanner says desired idle speed is 800. ive got no codes and nothing is out of line. but should my idle speed be down to 800 or is 1000 fine? thanks trey
Old Aug 14, 2003 | 10:03 PM
can_silver_z's Avatar
Mine has always idled at just a smidgen over 900...
Old Aug 14, 2003 | 10:04 PM
Lyle A's Avatar
Mine too, but I think specs say 800.
Old Aug 14, 2003 | 10:10 PM
Zs_Z28's Avatar
How much is a smidgen ?
Old Aug 14, 2003 | 10:11 PM
Lyle A's Avatar
About the same as a tish
Old Aug 14, 2003 | 10:19 PM
The stock programming sets the idle speed at 800rpm, fully warmed up coolant. Mine idled there, +/-25rpm, consistantly. Of course that's reading it from the PCM, and not from the stock tach, which typically read 900-950rpm.
While checking the idle with a scanner, check the IAC counts. They should be in the range of 20-40 counts, varying slightly to pull the idle back to 800rpm. If the IAC counts bottom out at "0" before the idle comes down to 800rpm, you might have the TB blades open too far, or a vacuum leak.
Old Aug 14, 2003 | 10:21 PM
mirroredfire2's Avatar
maybe your tach is off.. just a thought =/
Old Aug 14, 2003 | 10:29 PM
thanks fred. i was wondering what my IAC count should be. ill check it out and see what happens. as far as the tach the PCM is reading 1000 and the tach shows exactly that. thanks trey
Old Aug 14, 2003 | 10:54 PM
Johnnynsac's Avatar
Mine Idles right at 1000 cold and when warm.
Old Aug 14, 2003 | 10:55 PM
jasons93z's Avatar
It should go down to about 800rpms when warm
Old Aug 14, 2003 | 11:06 PM
Here's the tables from the PCM:
COOLANT----- A4-------A4----------M6
TEMP----------IN---------IN
deg F--------GEAR----NEUTRAL
-40 degF-----800------1200------1200
-19degF ---- 800------1200------1050
3degF---------800------1200------1050
24degF-------800-------1000------1000
46degF-------800--------950-------900
68degF-------800--------900-------900
89degF-------800--------900-------900
111degF------800-------900-------800
132degF------750-------850-------800
154degF------650-------750-------800
176degF------550-------650-------800
>176degF-----550-------650-------800
Old Aug 14, 2003 | 11:07 PM
Johnnynsac's Avatar
So if it doesn't, what does that mean?
I bought the car 4 years ago like that and it's never changed
Old Aug 15, 2003 | 03:36 PM
SlickBlack Z's Avatar
As far as I know, the factory tachometers usually read about 200 RPM's higher than the actual RPM's. My tach shows 1000 at idle but when hooked up to a scanner it's actually idling at 800. Just some food for thought.
DirtyDaveW
Dec 1, 2016 05:37 PM
edman
Mar 13, 2015 09:39 PM
sloppytot
Feb 25, 2015 08:30 PM
edman
Jan 25, 2015 02:41 PM
Jul 4, 2005 05:00 PM
