Cooling system help after opti change
Old Mar 3, 2011 | 06:12 AM
Bigjaycass's Avatar
I have a 95 Z28 and had to swap out my opti. I put everything back together and filled the radiator with coolant, then started it up. The temp went up to almost the red zone and I shut it down. I let it cool down and once it did the hose on the passenger side was collapsed. I pulled the cap off and put more coolant in the car and did the same thing with same results. I didn't bleed the air, could that be the problem? I thought I could just do it like the old cars, but I guess it works different. Any info for me?
Old Mar 3, 2011 | 06:31 AM
Re: Cooling system help after opti change
Originally Posted by Bigjaycass
... and put more coolant in the car and did the same thing with same results. I didn't bleed the air, could that be the problem? I thought I could just do it like the old cars, but I guess it works different. Any info for me?
Yes, that is the problem. There is a specific fill procedure.
http://shbox.com/1/4th_gen_tech2.html#radflush
Old Mar 3, 2011 | 07:14 AM
Bigjaycass's Avatar
My car only has one blessed screw, guess the guy I bought the car from remove that other hose. Any other area I should open to help bleed off the air? I had read that you can bleed air from the TB bypass hose, is that correct?
Old Mar 3, 2011 | 08:03 AM
How are you going to bleed air from a hose that has no bleed screw? Just use what you have.
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
grgguy
17
Feb 23, 2015 07:57 PM
kksi
Feb 17, 2015 10:41 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
