idle air control connector???
Old Oct 17, 2010 | 07:36 PM
MyFastTA's Avatar
ok I have been installing my new engine and transmission today! It was real sweet to hear the thing fire up but I do have a few kinks to work out. First was I have a flat 4 wire connector for the IAC but on the IAC its a square 4 wire connector??? what is that about...I bought the throttle body with the IAC on it already.... My question is can I just buy a IAC with the correct plug that I need or what?
Old Oct 17, 2010 | 08:42 PM
Is it possible the previous owner of the TB had a 93? The IAC is different on the 93's.
Old Oct 17, 2010 | 09:23 PM
The IAC that fits your plug would not fit in the lower TB plate. You could swap lower plates to a later model to be able to use the IAC that fits the flat plug.
93s have screw-in IACs with a square plug.
94-97s have bolt-on IACs with a flat plug.
Old Oct 18, 2010 | 08:35 AM
MyFastTA's Avatar
I see now...would it be easier for me to just get a 93 pigtail and rewire or would you recommend just getting the right iac and housing??
Old Oct 18, 2010 | 10:40 AM
It's really your choice. I'd stick with the flat connector, since that is what your year uses.
Old Oct 18, 2010 | 07:46 PM
wayneg1035's Avatar
My car 94 Z28 had a short extension 6" that converted the square connector to the flat one for the original IAC. When I rebuilt my throttle body (kit) it came with a new IAC with the square connector. I noticed the extension and removed it and the harness plugged right into the new IAC. Check your harness it might be the same
Old Oct 18, 2010 | 09:55 PM
That's not something factory. Someone added it.
Old Oct 18, 2010 | 10:19 PM
wayneg1035's Avatar
Your probably right, the car in the mid 90's had an accel DFI computer on it instead of the factory PCM so it could be programmed for the cam and supercharger, maybe something got spliced then. In 2001 I hooked the factory computer back up because LT1 Edit was out and you could program the factory PCM. It's amazing I cant remember **** I did to the car back then.
Old Oct 18, 2010 | 11:05 PM
MikeGyver's Avatar
Just splice on the required plug.
Old Oct 19, 2010 | 11:26 AM
MyFastTA's Avatar
thank you very much for that diagram I was looking for something to make sure I wired it right...and did not find that thank you again. The pigtail is in at the parts store so I will get it today and wire it up. Just the right IAC alone the parts store wanted $60 and I would then have to get the housing...the plug is like $16 so it was a no brainer to me...I need the extra money for the tune. Thanks again
Bryan
Old Oct 20, 2010 | 04:36 PM
Didn't you already have a throttle body with the correct IAC motor/connector on it? If so, the option was to simply swap the bottom plates.
Old Oct 20, 2010 | 08:27 PM
MyFastTA's Avatar
that would make sense but i do not have the stock tb got lost in a move somewhere??? no idea where it is
Old Oct 21, 2010 | 04:10 PM
MyFastTA's Avatar
I am confused on shbox.com and others the wire colors are ltblu/white ltblu/black and ltgreen/white and ltgreen/black but on my harness it is 2 ltgreen/white and 2 ltgreen/black wires????any help
Old Mar 2, 2011 | 09:18 AM
rsm93z28's Avatar
Re: idle air control connector???
I'm one of those who finds himself "Lost in OptiSpark Land" on my 1993 Z28 LT1; what with with all the unfortunate mission creep that comes with having to change the following things all at once:
OEM Y-Pipe and CAT and O2 sensors
Spark Plugs
Spark Plug Wires
OptiSpark
Water Pump
two of the three Timing Cover Seals
...and meanwhile these have crept in along with the aforesaid...
Throttle Body Service
Intake Manifold Clean-out
Air Elbow... (It was ruptured and leaking straight dirty air for GOKHL)
TPS
IAC....
and now the problem I'm faced with relevant to this OP's issue(s) i involves the fact that when I unsnapped and tried to remove the pale green four-pin weatherproof connectors form the IAC ...it just crumbled into pieces in my hand like a stale cookie. So I could use some help in finding a replacement IAC connector/pigtail if someone would point me in the right direction... I'd be very grateful.
Old Mar 2, 2011 | 02:36 PM
MikeGyver's Avatar
Connectors are sold on ebay and (eficonnection.com)
