cooling problem
Old Jan 24, 2009 | 12:44 AM
harrington333's Avatar
cooling problem
Hi there everybody.I'm just wondering if it's okay to run the LT1 at 200f with fan 1 on all the time.I thought the fans only came on at 225f but it's coming on at 200f.I have a 195 degree thermostat in there now for the winter.I guess the question is will the fan burn out running all the time and is it safe to be running at 200f.Thanks.
Old Jan 24, 2009 | 01:45 AM
stopthatman's Avatar
yeah mine is programmed to come on at 185 and the 2nd at 200 i think, w/ the 160 stat. so my #1 is probably running most of the time at speeds under 50 or whatever speed that is when the sensor turns it off with enough air flow
Old Jan 24, 2009 | 07:11 AM
I would not run anything higher than the stock 180° thermostat. Stock fans come on a 226°. There is no reason to have the fans run all the time. You are just creating more drag on the engine with the alternator having to produce the power to run them.
Old Jan 24, 2009 | 05:02 PM
cooling problem
Thanks for the info.What if the temperature is 40f outside will the 180 thermostat be to cool or does it work in all temperatures.Thanks.
Old Jan 24, 2009 | 06:34 PM
moparman's Avatar
The 180 will produce plenty of heat at 40F. We've been down around 0 a couple days, and my car had plenty of heat with the 180.
Old Jan 25, 2009 | 10:12 AM
Yes it works just fine at ALL outside ambient temperatures. That's why GM selected it as the stock t'stat rating. Remember, the LT1 uses the unique "reverse flow" cooling system, resulting in the need for a lower t'stat rating. I run a 160*F t'stat, and get all the heat I need, even when temperatures approach 0*F.
BigWil
Mar 29, 2015 12:24 PM
Lt4Z2897
Mar 26, 2015 03:02 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
MattFick
Feb 15, 2015 10:16 PM
