Maybe Blown Head Gasket ?
Old Jan 13, 2009 | 12:51 AM
lt1le2's Avatar
Ok I took my valve covers off to check my lash and found some milk on the passanger side valve cover. I drained the oil and found no signs of water in the oil I took the sparkplugs out and nothing came out of holes My coolent level is fine I also drained it and it was nice and green. Would the Cold cause this to happen if the car sits for about 3 months in the 15-20 degree weather
Old Jan 13, 2009 | 10:33 AM
lt1le2's Avatar
milk
Anyone ?
Old Jan 13, 2009 | 05:43 PM
Originally Posted by lt1le2
Anyone ?
Wrong forum. This topic is basic "LT1 Based Engine Tech" material. You'll get a lot more responses there. I'll move it to the correct forum for you.
PS: The answer is yes, cold weather and/or short drives will cause what you are seeing.
Old Jan 23, 2009 | 09:29 AM
mr_wizard's Avatar
I know when I drained the coolant and oil when I blew my headgasket I did not see any sort of mix, but I was blowing out ALOT of smoke and running very sluggish. My plugs also looked fine. If the lt1 is running a bit sluggish or you're seeing alot of smoke, get it diagnosed at a mechanic for about 40$. That's what I did.
Old Jan 23, 2009 | 10:33 AM
quickchek321's Avatar
yea man if u are blowing white smoke might have a problem is it shaking when it idleing
Old Jan 23, 2009 | 10:47 AM
rbaksi's Avatar
yeah the weather could do it, but I would really watch for white smoke, that would be a telltale sign of the gasket blowing.
Old Jan 25, 2009 | 11:33 AM
ibanez6rg's Avatar
Common thing that I saw in the winter with mine. I wouldn't worry about it.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
