cooling problem
Old Apr 18, 2005 | 12:57 PM
350pride's Avatar
cooling problem
I have a 94z and i just installed a summit electric water pump. My problem is that my car is now running at about 195 instead of 180. I put a factory thermostat back in and, Im wondering if i went with a 160 stat whether that will help keep it cooler even though I do not have my fans programed to come on then or will i just be wasting my money since my fans are not programed.
Ps I did bleed my valves with heat on high.
Old Apr 18, 2005 | 01:42 PM
Re: cooling problem
It's normal for the engine to run 10°-20° higher than the thermostat setting. If you put in a 160° thermostat, you will run ~175°.
Old Apr 18, 2005 | 11:22 PM
350pride's Avatar
Re: cooling problem
Man im glad to hear that i just thought that the water pump. Now i guess ill go buy a $20! thermostat. Does any one no why advance and autozone quit selling $7 160 thermostats for the LT1.
ps thanks shoebox
BigWil
Mar 29, 2015 12:24 PM
Lt4Z2897
Mar 26, 2015 03:02 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
MattFick
Feb 15, 2015 10:16 PM
